Is it possible to enable voice control?
Chassis Type: 8T0
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 1B 3C 42 46 47 52 53 55
56 5F 62 6C 72
VIN: LFV3A28K8A3030688 Mileage: 890km/553miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H16 0008
Revision: E1H16---
Coding: 0104000C02070160
Shop #: WSC 03333 000 00000
ASAM Dataset: EV_ECM20TFS8K2907115P A01010
ROD: EV_ECM20TFS8K2907115P.rod
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K0 927 155 AC HW: 0AW 927 156 H
Component: 0AW 20TFSIRdW H05 0006
Revision: --H05--- Serial number: 0000000920
Coding: 000001
ASAM Dataset: EV_TCMVL381 A02017
ROD: EV_TCMVL381.rod
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8KD 907 379 B HW: 8KD 907 379 B
Component: ESP8 front H05 0030
Revision: -------- Serial number: --------------
Coding: 086D08
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0328
Revision: 00002001
Coding: 050100
Shop #: WSC 02222 000 00000
Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AM HW: 8T1 820 043 AM
Component: KLIMA 1 ZONE H08 0171
Revision: A0000000 Serial number: 01080420101693
Coding: 64106000
2 Faults Found:
00657 - Positioning Motor for Central Vents (V102)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 52
Mileage: 64 km
Time Indication: 0
Date: 2010.09.26
Time: 09:10:53
Freeze Frame:
Voltage: 12.80 V
Temperature: 26.0癈
Temperature: 29.0癈
Count: 11334
Count: 11909
Bin. Bits: 00000000
Bin. Bits: 10000001
Time: 8.00 s
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 75
Mileage: 777 km
Time Indication: 0
Date: 2010.10.09
Time: 20:31:55
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H29 0392
Revision: 09029001 Serial number: 00000000684545
Coding: 260050914030AF311701000000001D0D4F9CC3480201010100 0000
Part No SW: 8K1 955 119 A HW: 8T1 955 119
Component: WWS 100510 H06 0070
Coding: 00FD11
Part No SW: 8K0 955 559 HW: 8K0 955 559
Component: RLS H04 0003
Coding: 025028
Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Address 0E: Media Player 1 (R41) Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 L HW: 4E0 035 110 A
Component: CDC-MP3-Pana H49 0050
Revision: 00000015
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 8KD 919 475 B HW: 8KD 919 475 A
Component: PARKHILFE 8K H02 1072
Revision: 11001001 Serial number: --------------
Coding: 300103
Shop #: WSC 00000 000 00000
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0HVX48
Coding: 304D3437453030303030554A304C384B4453
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319JBP000JM
Coding: 000036
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: None
Part No SW: 8KD 920 930 A HW: 8KD 920 930 A
Component: KOMBIINSTR. H18 0255
Revision: 00200000 Serial number: F1D94H27A
Coding: 0F0F08002B0000080E0000
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AE HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0117
Revision: FC100058 Serial number: 5800F10411005C
Coding: 00C303
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 287 km
Time Indication: 0
Date: 2010.09.28
Time: 12:14:17
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.10 V
Count: 11
Bin. Bits: 00000
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 D HW: 8K0 907 144 D
Component: DYNAMIKLENK. H06 0570
Revision: 50001005 Serial number: --------------
Coding: 0C0000
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 8K0 907 566 B HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0070
Revision: 00H01000 Serial number: 6PZ 009 014-13
Coding: 0000110
Part No: 8K0 907 568 B
Component: J0770_SWA_Slave_H01 0070
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000010973813
Coding: 011C12205E00410001
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 12
Mileage: 297 km
Time Indication: 0
Date: 2010.09.28
Time: 15:27:45
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0130151811
Coding: 011E0E20003900850330013280000000
Shop #: WSC 08888 000 00000
Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
Address 47: Sound System (J525) Labels: None
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34882002083401
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000010975930
Coding: 011C12205C00410001
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000492780
Address 55: Xenon Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 A HW: 8H0 907 357
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Part No: 8K0 941 329
Component: AFS-Modul links H02 S001
Component: AFS-Modul rechtsH02 S001
Address 56: Radio (R) Labels: None
Part No SW: 4F0 035 053 D HW: 4F0 035 053
Component: Radio U Basic H45 0023
Revision: AB001007 Serial number: 011DQ0A7545067
Coding: 090003010000000001
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8KD 035 666 A HW: 8KD 035 666
Component: H-BN-CN H15 0011
Revision: -------- Serial number: K5FAN153A2ISE
Coding: 010700000206E1EF15000F0E00000001
Part No: 8R0 919 884 A
Component: CHN-22.05.09. 7203
Part No SW: 8KD 919 604 HW: 8KD 919 604
Component: DU7 High H43 0306
Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 77
Mileage: 794 km
Time Indication: 0
Date: 2010.10.10
Time: 21:12:47
Freeze Frame:
Bin. Bits: 00010000 00000000
Bin. Bits: 00000000 00000000
02259 - Information Display and Control Head (Front) (J685)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 52
Mileage: 287 km
Time Indication: 0
Date: 2010.09.28
Time: 12:05:04
Freeze Frame:
Voltage: 12.30 V
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000010994018
Coding: 010C12204000210001
Address 6C: Back-up Cam. Labels: 4L0-910-441.lbl
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H04--- Serial number: 525PA8-J0392X8
Coding: 1021006
Shop #: WSC 05555 000 00000
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000010991913
End ---------------------------------------------------------------------
Since that's a 2010 car, we must insist that you use a CURRENT version of VCDS.
http://www.ross-tech.com/vcds/download/current.html
