Post overhaul codes help (VAG-COM Rocks!)
I have an 01 A4 1.8t Auto with 74k miles. The head ran short on oil with the previous owner so I replaced the head and reworked the bottom end with new bearings. I got the car running and had the CEL, ABS, and BRAKE illuminated. I ran the VAG-COM "engine" diagnostic and came up with the following codes. If anyone can point me in the right direction or if there is something I still need to do after an overhaul (ie cam sensor adjustment) to get this A4 purring please let me know. Your knowledge is greatly appreciated.
(Engine scan before clearing)
Wednesday, 11 June 2008, 22:44:01
VAG-COM Version: Release 409.1-US
Control Module Part Number: 4B0 906 018 M
Component and/or Version: 1.8L R4/5VT G 0002
Software Coding: 16251
Work Shop Code: WSC 85555
15 Faults Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
17536 - Shareware Version. To Decode all DTCs
P1128 - 35-10 - Please Register/Activate - Intermittent
17511 - Shareware Version. To Decode all DTCs
P1103 - 35-10 - Please Register/Activate - Intermittent
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 35-10 - - - Intermittent
16712 - Shareware Version. To Decode all DTCs
P0328 - 35-10 - Please Register/Activate - Intermittent
16717 - Shareware Version. To Decode all DTCs
P0333 - 35-10 - Please Register/Activate - Intermittent
17733 - Knock-Control: Cylinder 1: Regulation Limit Exceeded
P1325 - 35-10 - - - Intermittent
17735 - Shareware Version. To Decode all DTCs
P1327 - 35-10 - Please Register/Activate - Intermittent
17734 - Shareware Version. To Decode all DTCs
P1326 - 35-10 - Please Register/Activate - Intermittent
16725 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 35-10 - - - Intermittent
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
16705 - Shareware Version. To Decode all DTCs
P0321 - 35-10 - Please Register/Activate - Intermittent
16706 - Engine Speed Sensor (G28): No Signal
P0322 - 35-10 - - - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16688 - Shareware Version. To Decode all DTCs
P0304 - 35-00 - Please Register/Activate
(Engine scan after clearing codes)
Wednesday, 11 June 2008, 23:05:45
16 Faults Found:
P1606 - 35-00 - -
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
Dave
Waldorf MD
15 Faults Found:
P1606 - 35-00 - -
16 Faults Found:
P1606 - 35-00 - -
P0301 - 35-00 - -
Dave
Waldorf MD
One more thing, the idle is pretty rough most of the time and after running in the driveway for about 15-20 min, the Cat was glowing, I assume from the missfires passing a lot of unburned fuel down the pipe?
Thanks
Dave
Thanks
Dave
<ul><li><a href="http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=VSWR& ;Category_Code=VAGCOM">http://www.ross-tech.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=VSWR& ;Category_Code=VAGCOM</a</li></ul>
Andy
Andy
I just started using it last night, figured I would try it out and see how useful it is. As soon as I get this car on the road, I will upgrade/register, probably at my next pay period. I do see the value in registering. Thanks!
CrazyINP-12V Ivan
01-18-2007 08:54 AM
Iggy_r1
12-21-2005 02:39 PM
StreetCrawler(Cole)
10-18-2004 02:19 PM
cpbetts
02-24-2004 11:05 AM
