Power locks blinking and clicking, fuse 39
Well, its actually a B5 (1998) Passat actually. I know! But it has the heart transplanted from my 1998 A4 1.8T including ECU.
I was trying to fix the door lock on driver side ('spinning cylinder'), swapped passenger side lock over.
Door cards and regulator out.
Somewhere in the middle, I noticed the passenger side door lock and the TRUNK (nothing done there) did not close (meaning the lock does not snap in; door always stays open).
Thought it may have to do with the door switches unplugged, etc.
Put everything back together. Same thing.
Also noticed that the door LED is blinking like crazy, and a relay under the fuse box is clicking like mad.
Did not want to burn anything out, so found that pulling fuse 39 disables the power locks and stops the clicking and blinking.
Now close to finishing up, but can't get the passenger door lock to snap close, nor the trunk.
And the clicking and blinking continues.
Disconnected battery for 10 min. Nothing.
Plugged in VAGcom. With fuse in, cannot connect to ANY module.
"Not plugged into car", "interface not ready" (even after running options, etc.).
With the fuse 39 out, I can read some modules (scan below).
Before messing with the locks and door card, everything was working, including remote control.
Car starts and runs, no engine codes.
What is going on here?
Video link below shows the blinking and clicking. With 'key on' and with 'key out'.
http://s853.photobucket.com/albums/a...9-20-16-26.mp4
Intelligent boot not checked, power door lock fuse removed.
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Tuesday,09,October,2012,20:11:36:36008
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Mileage: 285800km/177587miles
Address 01: Engine Labels: 058-907-55x-AEBN.lbl
Part No: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D02
Coding: 06201
Shop #: WSC 00001
VCID: 3D71816537FD06F00A3
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 P
Component: ABS/EDS 5.3 FRONT D31
Shop #: BB 24304
VCID: 2B55BF3DD9899840A47
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 607 B
Component: AIRBAG VW3 S V03
Coding: 00066
Shop #: WSC 05311
VCID: 2C57BC21DC879F78ADD
1 Fault Found:
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
29-00 - Short to Ground
Address 17: Instruments Labels: 3B0-919-xxx-17.lbl
Part No: 3B0 919 930 R
Component: B5-KOMBIINSTR. VDO V10
Coding: 06242
Shop #: WSC 00000
VCID: 36639E4912CBD5A8CB9
End ---------------------------------------------------------------------
Coding: 06201
Shop #: WSC 00001
Shop #: BB 24304
Coding: 00066
Shop #: WSC 05311
1 Fault Found:
Coding: 06242
Shop #: WSC 00000
Reinman
03-26-2008 01:22 PM
JordanCDA
10-02-2002 06:49 PM
