Problem using "04 Basic Setting"
I am trying to run a basic setting using VAGCom under the engine control module. When I select "04 Basic Setting" And hit start/next as instructed in the SW I get and error saying this function is not available. Any idea what might cause this?
thanks
thanks
On what control module, in what make/model/year/engine of car?
I can't think of anything in a 1998 car to which the Start/Next button in Basic Settings would apply.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
I am trying to run the leak detection pump. According to the Bentley page 20-100, this is a basic setting, address 71.
I am able to review the leak test status using display field 3, address 32, I am able to see the reed valve status.
If you know another way to run the leak detection pump I am open. Right now it looks like a software issue.
Thanks
Thanks
even has a Leak Detection Pump to run? There were no mandatory "OBD" requirments in Europe in 1998! I think even current European emissions standards don't require an evaporative leak detection system.
-Uwe-
-Uwe-
I can send you a pics if you like.
The car has all US spec controllers, and I can see the LDP reed status on address 34. I have pulled the left rear wheel well, and have been inspecting the LDP.
What is the deal with the software? Do I need to call your customer service, or can you help me with it?
Thanks
Thanks
I think you problem is procedural, not a problem with the software per se. But I can't say I've ever done that particular test on that particular car.
Try this: Go to 071 in Measuring Blocks. Then use the Switch to Basic Settings button after you've verified that field 1 says "Reed Closed".
-Uwe-
-Uwe-
test. Also the Bentley mis states the address, it should be 34. I verified this on another A8.
turbo510
VAG-COM Discussion
08-21-2011 06:40 PM
apostle411
02-23-2010 09:42 PM
