Problem with VAGCOM.
I had no problems with VAGCOM nor my comp until today when I could not log channels above 25, when I discovered that my copy has somehow deactivated. I purchased a copy of the full version in Sept. and now I can't activate it.
I have the Activation code from Linda corresponding to the serial number I sent to Ross-Tech but putting that activation code on the copy of the expired VAGCOM gives an invalid error that it does not match to the serial number.
What do I do? I need to reformat my comp but what info does Ross-Tech need so that I can reactivate it after reformat.
Thanks,
Alen
Thanks,
Alen
and VAG-COM has becoem de-activated, chances are the two conditions are related. So long as you're using the same PC, it shouldn't be a big deal. Some links for your persual:
http://www.ross-tech.com/vag-com/faq_5.html
http://www.ross-tech.com/vca/short-form.html
-Uwe-
-Uwe-
http://www.Ross-Tech.com
i still haven't reformatted and vag-com has become deactivated.
i still have the same application file.
if i don't deactivate it, reformat the computer and use this same application file to install vagcom can i use the same activation code i have in email?
using the form at the link below.
-Uwe-<ul><li><a href="http://www.ross-tech.com/vca/short-form.html">http://www.ross-tech.com/vca/short-form.html</a</li></ul>
Hello -
I am sorry but this serial number does not decrypt as the same PC that you had previously registered with us. Please send us a deactivation for the earlier copy of VAG-COM and we will be happy to send you a new activation code.
For more information on deactivations, please see this link from our FAQ:
You will find detailed instructions on how to deactivate at the bottom of FAQ entry, question number 5.2.
Best Regards,
Linda Ross
Ross-Tech LLC
This is the same laptop that I had vagcom on before. So how can we solve this issue?
Best Regards,
Linda Ross
Ross-Tech LLC
you gave no explanation whatsoever when you filled out the form. Yet the form clearly states:
"If this is not your first request for an activation code and you are not supplying a de-activation code, you must provide a detailed explanation here."
OTOH, the boiler-plate response you got wasn't really the correct one for this situation, and for that I apologize.
Check your e-mail again.
-Uwe-
-Uwe-
does but there's the 'and'. either way thanks for the service. you guys rock.
davids_s4
16
10-24-2006 03:02 AM
undrway
09-21-2001 06:23 AM
