Q7 POS please help
#14
Please do the following and post an updated scan. Thanks.
As I suggested, please clear the DTCs, drive the vehicle and scan it again.
#15
HVAC is still showing the same, i tried excersizing the flaps and they sounded off, but still shows v300 is a problem. same problem with the oxygen sensor, all the rest are gone.I will repost when the boss gets home. Not sure if i excercised the flaps correctly, which oxygen sensor is bad.
#18
Probably wouldn't be a bad idea to fix it anyway though.
If there isn't a thread in the Q7 forum on how to do it, you'll have to check the factory repair manual.
Best place is https://erwin.audiusa.com if your are in the US.
#19
im on night shift this week, i will try to excersise the flaps again not sure if i did it right yesterday, although i did here them, i replace the cabin air filter, maybe it a loose connector. I will check then. No mil, clear dtcs and ran a test, still showing faults mentioned. Thanks for the help. Im used to 428cobrajet and concours mustang forum, much more lively over there.
#20
No worries - we're all here to help.
Edit:
This VCDS forum is pretty specialized and crosses all models.
It's usually pretty quiet, unlike the model specific ones around here.
Edit:
