Question: Need help why Ext Temp is not displaying
Members of the Brain Trust:
Im puzzled and stumped - I have a 2003 Audi allroad and up until a short while ago I always had the Ext Temperature displayed on the FIs /DIS
This stopped about 5 days ago and I cant tell why. No errors on VAGCOM relating to this (yes I know about the little button to toggle the DIS)
I have the Infotaimnent bus on Ch63 in Instruments set to 7 as per the suggestion of this forum (was 23 I think) the Comfort Bus is coded for Parktronic + Instruments + Allroad
No idea - when I look at the HVAC and go to block (11 I think) - it shows a temperature reading where the Bentley says it should.
So what Im wondering is - is the temp sensor working? Is the temp field in the HVAC an interpolated one (I know it also has an interior temp sensor)
Very strange - wouldnt there be an error code if the sensor was not working
Popped the hood and checked - its there and plugged in.
Scan Posted ( I cleared all the aforementioned codes and they have not come back - my mechanic was working on the steering wheel)
VCDS Version: Beta 803.1
Data version: 20080108
Monday,07,April,2008,13:10:14:28032
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WA1YD64B93N001011
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0010
Coding: 07755
Shop #: WSC 78646
WA1YD64B93N001011 AUZ7Z0B2141391
5 Faults Found:
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
16686 - Cylinder 2: Misfire Detected
P0302 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 4Z7-927-156.lbl
Part No: 4Z7 927 156 M
Component: AG5 01V 2.7l5VT USA 2122
Coding: 01032
Shop #: WSC 02325
No fault code found.
Address 03: ABS Brakes Labels: None
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06397
Shop #: WSC 00000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
Address 15: Airbags Labels: None
Part No: 4Z7 959 655 J
Component: Airbag 8.4EP 2000
Coding: 0000607
Shop #: WSC 02325 785 00200
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 H
Component: Lenkradelektronik D01
Coding: 01015
Shop #: WSC 12345
3 Faults Found:
01303 - Telephone Transceiver (R36)
49-10 - No Communications - Intermittent
01301 - Control Module for Voice Recognition (J507)
01304 - Radio
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 04264
Shop #: WSC 19411
2 Faults Found:
01304 - Radio
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15917
Shop #: WSC 01029
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 4B0 035 192 P HW: 4B0 035 192 P
Component: RNS-E US3 H54 0200
Revision: 08S Serial number: AUZBZ7E0500156
Coding: 0519636
Shop #: WSC 00000 781 01234
4 Faults Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 3
Reset counter: 151
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
00467 - TV Tuner (R78)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
02218 - Satellite Radio (R146)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00030
Shop #: WSC 02325
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0519636
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 151
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 00000
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 R HW: 8P0 862 335 L
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005043205
Coding: 0010877
Shop #: WSC 00000 000 00000
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 86
Reset counter: 147
End ---------------------------------------------------------------------
76 77
Coding: 07755
Shop #: WSC 78646
5 Faults Found:
Coding: 01032
Shop #: WSC 02325
Coding: 06397
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 02325
Coding: 0000607
Coding: 01015
Shop #: WSC 12345
3 Faults Found:
01304 - Radio
Coding: 04264
Shop #: WSC 19411
2 Faults Found:
01304 - Radio
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
Coding: 15917
Shop #: WSC 01029
Coding: 00001
Shop #: WSC 00000
Coding: 0519636
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 151
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Coding: 00030
Shop #: WSC 02325
Coding: 0519636
4 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 151
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 152
Time Indication: 0
Date: 2008.03.31
Time: 08:59:01
Coding: 01186
Shop #: WSC 00000
Coding: 0010877
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 86
Reset counter: 147
Go to Instruments (17)
Adaptation Channel 19
Car has to be coded XXX1X (mine was XXX0X) for the temperature to display.
This one was nowhere to be found! Not even in the VAGCOM software.
Had to go find it on OpenOdb for the A4
Yikes - can you update this please Uwe
YUM18T
05-13-2006 10:54 AM
GoodMatt
15
12-16-2005 10:17 AM
rd350
05-07-2005 10:22 AM
