Remote operation of windows, up OK down No
Please help
I use your product on 3 Audi's and am very happy with it.
Now have a problem with my 2009 A4 (B8) premium plus.
A few years ago when I first got the VAG-COM I programmed the car to allow the remote to open and close windows. Everything worked fine. (I also did this on my other two Audis). About 4 months ago the dealer had the car to do an oil consumption service bulletin. The dealer must have reprogrammed the car because when I got the car back, remote operation of windows didn't work. Also in Jan 2013, both driver door and left rear door were removed and replaced due to being T-boned.
Monday Jul 22, attempted to program for remote window operation. Used the long code helper function and also found the Window menu on the Audi MMI CAR function. Set it for front door and rear door. Windows close with remote but do not open with remote. Activated Sunroof and it opens and closes with remote.
The question, why don't the windows open with remote?
Below is the auto-scan from the A4 taken MOndayd. I notice it shows two faults for Address 46: Central Conv. (J393)
Is this a hardware problem or software or programming?
Second subject - Can the A4 be configured for Rest of World (Germany) lighting?
Monday,22,July,2013,11:55:32:45112
VCDS Version: Release 11.11.6
Data version: 20121223
Chassis Type: 8T0
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
65 72 77
VIN: WAUSF78KX9N016774 Mileage: 52270km/32479miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H12 0001
Revision: E1H12---
Coding: 0104010A190F0160
Shop #: WSC 22302 444 64321
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79F20805F8696AD0675
1 Fault Found:
4629 - ECM Power Relay Load Circuit: (J271)
P068A 00 [096] - De-Energized Performance Too Early
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0020
Revision: --H04---
Coding: 001002
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 3668C33989F745A8CA7
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 150500
Shop #: WSC 02399 823 56573
VCID: 79F20805F0696AD0675
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 090100
VCID: 336EFA2D92855080ED9
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01010220121163
Coding: 64002000
VCID: 7AF01709F56F61C86EF
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000074629
Coding: 26001091073CAF010000080300003D0D0F1C52080001016100 0000
VCID: 3064F52163936B9890B
Subsystem 1 - Part No SW: 8K1 955 119 HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 060708 H06 0060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
Component: AirbagVW-AU10 H26 0410
Serial number: 0039GD129J3W
Coding: 303836354230303030304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3D7ADC15ACC196F00BD
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0800000YMW
Crash sensor for side airbag; driver side:
Serial number: 6334MSME3F22204BC
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME3D317639J
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME7B03104FI
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME7D6F4A7FC
Crash sensor for front airbag; driver side:
Serial number: 63732SME4E7831193
Crash sensor for front airbag; passenger side:
Serial number: 63832SME7C31263B2
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90304HGC0007Z
Coding: 000016
VCID: 3D7ADC15A4C196F00BD
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 A HW: 8K0 920 950 A
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 98U347H78
Coding: 8B1F09000300D705020000
VCID: 2D5AEC5574A10670BBD
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G087118781
Coding: 000303
VCID: 4688B3F9F117D5285A7
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Component: SG ext.Player H06 0210
Revision: 00000000
Coding: 020302
VCID: F8F48D014B63F3D898B
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8K0 959 760 HW: 8K0 959 760
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001111161
Coding: 00581300000000000000
VCID: F7F68E3D467DFCA0911
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007461312
Coding: 011C03204E00410001
VCID: 3F86A61DAECD84E0191
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0113097214
Coding: 0106063A007A440400B001
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
2 Faults Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 46
Reset counter: 201
Mileage: 46104 km
Time Indication: 0
Date: 2012.12.11
Time: 14:28:58
02615 - Fuel Tank Cap; Lock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 204
Mileage: 46124 km
Time Indication: 0
Date: 2008.02.08
Time: 04:15:30
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S1900000
Coding: 0203010102
VCID: 6ED82B59B9273D68C27
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007469267
VCID: 3E78DB19A9C78DE8127
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000167083
Shop #: WSC 00000 000 00000
VCID: 3162F025689962909F5
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
VCID: 346CF931578B57B8F43
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1033600
Coding: 040200020101850043D9070800
VCID: 4084A5E1D333FB1860B
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 142
Mileage: 46090 km
Time Indication: 0
Date: 2012.12.11
Time: 13:19:06
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007443302
Coding: 010C03204000210001
VCID: FF06661D6E4DC4E0D91
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 13140785998970
Coding: 0CD154
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007424959
VCID: FEF89B196947CDE8D27
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 A HW: 8T0 862 336 A
Component: FSE_256x BT H33 0520
Revision: 00000000 Serial number: 00000005006939
Coding: 0010370
VCID: 3972C80570E9AAD0275
End ---------------------------------------------------------------------
Chassis Type: 8T0
65 72 77
Revision: E1H12---
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Revision: --H04---
Coding: 001002
Coding: 150500
Revision: 00002001
Coding: 090100
Coding: 64002000
Coding: 00FD11
Coding: 025028
Coding: 000016
Coding: 000303
Revision: 00000000
Coding: 020302
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 46
Reset counter: 201
Mileage: 46104 km
Time Indication: 0
Date: 2012.12.11
Time: 14:28:58
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 204
Mileage: 46124 km
Time Indication: 0
Date: 2008.02.08
Time: 04:15:30
Revision: S1900000
Coding: 0203010102
Coding: 0000004
Component: Display
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 142
Mileage: 46090 km
Time Indication: 0
Date: 2012.12.11
Time: 13:19:06
Coding: 0CD154
Coding: 0010370
Audiworld Premium Sponsor
Don't know if this will sound stupid to you but perhaps the control module has forgotten the upper and lower limits of the window travel. I've seen weird things like this happen before.
Roll the window completely down using the window down button in the door. When the window gets to the bottom, hold the button in the down position for 30 seconds.. Now run the window up. Hold the button in the up position. Now test that you can tap the switch for the window to go down and tap it for the window to go all the way up.
Now see if the remote function will make it do what it should do.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
user Brozee did a thread on this over in the D3 A8 forum. You may want to search that and check the coding. I'm not familiar with the A4's so can't help specifically, sorry.
K9
K9
skl1
06-12-2007 08:18 AM
caster
10
05-19-2004 06:25 AM
