Removed and replaced ABS fuse now lots of problems... :(
I removed the ABS fuse whilst drying to troubleshoot a problem then quickly replaced it this afternoon however it seems to have set off a chain of events which basically means everything has gone up the kazoo.
I also removed the black plastic pin cover above the right hand fuse panel, under the same cover but a black cover with lots of pins underneath and purple plastic hinge. This may be more the problem anyhow ...
This is in an Audi A8 D3.
ABS doesn't work, a/c, door closing, windows, central locking etc etc etc.
Having a look via VAGCOM it can't communicate with lots of modules "Cannot be reached" such as Auto HVAC etc.
Clearing faults doesn't make any difference.
Having a look at the vagcom log produces the below. As the ABS was the most visible sign of the problem I tried to clear that and recode the steering sensor however it wont calibrate properly and I guess I am probably missing something more important!
Any help greatly appreciated!
Thanks
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 1D 1E 25 28 34 36 37
38 42 46 47 4F 52 53 55 56 57 61 62 67 72 76 77
VIN: WAUZZZ4E95N004806 Mileage: 212950km/132320miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Cannot be reached 1100
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Cannot be reached 1100
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Cannot be reached 1100
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 Q HW: 4E0 907 560
Component: 4.2L V8/5V G 0030
Revision: 00000000 Serial number: AUX3Z0D6345603
Coding: 0011773
Shop #: WSC 00411 210 81348
VCID: 2F66DCC0C76F
1 Fault Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - Implausible Signal
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 S HW: 09E 927 156 A
Component: AG6 09E 4,2L5V RdW 0020
Revision: --H01--- Serial number: 0043832
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 3260D5B4D45D
3 Faults Found:
18290 - Powertrain Data Bus: Missing Message from Electric Parking Brake Controller
P1882 - 000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:15
Freeze Frame:
RPM: 704 /min
RPM: 640 /min
RPM: 0 /min
(no units): 30.0
(no units): 32.0
Temperature: 12.0∞C
T.B. Angle: 0.0∞
18275 - Powertrain Data Bus: Missing Message from Steering Wheel (J527)
P1867 - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:15
18271 - Powertrain Data Bus: Missing Message from Steering Angle Sensor
P1863 - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:15
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 00588 000 00000
VCID: 224025F484BD
2 Faults Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
00473 - Control Module for Elect. Park/Hand Brake (J540)
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H07 0160
Revision: 01604507 Serial number: AUX3Z0D6345603
Coding: 0412672
Shop #: WSC 00353 210 82099
VCID: D8B4C71C1261
Part No: XXXXXXXXXXX
Component: ELV XXXX
5 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
02072 - Control Module for Energy Management (J644)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
Shop #: WSC 00000 785 00200
VCID: 234E20F09BA7
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 132
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:27:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 132
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:27:49
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 E HW: 4E0 035 729 A
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 300GI047537622
Coding: 0000002
Shop #: WSC 00408 210 87194
VCID: 2E58C1C4C065
Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
No fault code found.
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBD4020655
VCID: 1C3C1B0CA6D9
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
Shop #: WSC 02313 785 00200
VCID: E3CEE0F05B27
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 H HW: 4E0 920 950 H
Component: KOMBIINSTR. VDO H49 0200
Revision: D03 Serial number: AUDID3D6000139
Coding: 0000428
Shop #: WSC 01184 210 94686
VCID: 295232D8F98B
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 160030460703A5
Coding: FCFF7FDC3B7504
VCID: E5CAFEE85513
Address 1D: Driver Ident.
Cannot be reached
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785
Component: SG ext.Player H09 0850
Revision: 00000000
Coding: 010000
VCID: 2B5EC8D0F377
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
VCID: D8B4C71C1261
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000016 Serial number: 00000000019860
Coding: 0000000
VCID: E1C2EAF8413B
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285437DCE281
Address 36: Seat Mem. Drvr
Cannot be reached
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C
Component: MNS ECE H43 0850
Revision: 00000000 Serial number: 353GL047543611
VCID: 3B7EF8900317
Address 38: Roof Electronics
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000004588
Coding: 0000017
VCID: 2A50CDD4FC8D
1 Fault Found:
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 132
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:27:57
Address 4F: Centr. Electr. II
Cannot be reached
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: T¸rsteuer.BF BRMH01 0060
Coding: 0032622
Shop #: WSC 02311 785 00200
VCID: 20442FFC8AB1
Address 53: Parking Brake
Cannot be reached
Address 55: Xenon Range
Cannot be reached
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304GZ047598367
Coding: 0000001
VCID: 3162DAB8D15B
Address 57: TV Tuner Labels: 4E0-910-146.lbl
Part No SW: 4E0 910 146 G HW: 4E0 919 146
Component: TV analog TUNER H12 0300
Revision: 00000025 Serial number: 00000000004153
Coding: 0001003
VCID: 254A3EE89593
Address 61: Battery Regul.
Cannot be reached
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: T¸rsteuer.HL BRM002 0060
Coding: 0032622
VCID: 1E381104B0C5
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000406180048
Shop #: WSC 12336 024 394758
VCID: 3668E9A43835
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730418201621
Coding: 0101008
VCID: 21422AF881BB
1 Fault Found:
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 132
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:53:28
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 B HW: 4F1 862 335
Component: BTA H07 0900
Revision: 00H07000 Serial number: 00000007504117
Coding: 0060021
Shop #: WSC 20028 123 00000
VCID: 234E20F09BA7
End
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Thanks
Chassis Type: 4E0
Coding: 0011773
VCID: 2F66DCC0C76F
1 Fault Found:
Coding: 0000001
VCID: 3260D5B4D45D
3 Faults Found:
P1882 - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:15
Freeze Frame:
RPM: 704 /min
RPM: 640 /min
RPM: 0 /min
(no units): 30.0
(no units): 32.0
Temperature: 12.0∞C
T.B. Angle: 0.0∞
P1867 - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:15
P1863 - 000 - -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:15
Coding: 0007597
VCID: 224025F484BD
2 Faults Found:
Coding: 0412672
VCID: D8B4C71C1261
Component: ELV XXXX
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:49:32
Coding: 4063840
VCID: 234E20F09BA7
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 132
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:27:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 132
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:27:49
Coding: 0000002
VCID: 2E58C1C4C065
Cannot be reached
Cannot be reached
VCID: 1C3C1B0CA6D9
Coding: 0431707
VCID: E3CEE0F05B27
Cannot be reached
Coding: 0000428
VCID: 295232D8F98B
VCID: E5CAFEE85513
Cannot be reached
Revision: 00000000
Coding: 010000
VCID: 2B5EC8D0F377
Coding: 0412672
VCID: D8B4C71C1261
Component: ELV XXXX
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 132
Mileage: 212944 km
Time Indication: 0
Date: 2010.10.24
Time: 11:51:08
Coding: 0000000
VCID: E1C2EAF8413B
Coding: 0015510
VCID: 285437DCE281
Cannot be reached
VCID: 3B7EF8900317
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0000017
VCID: 2A50CDD4FC8D
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 132
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:27:57
Cannot be reached
Coding: 0032622
VCID: 20442FFC8AB1
Cannot be reached
Cannot be reached
Coding: 0000001
VCID: 3162DAB8D15B
Coding: 0001003
VCID: 254A3EE89593
Cannot be reached
Coding: 0032622
VCID: 1E381104B0C5
VCID: 3668E9A43835
Cannot be reached
Coding: 0101008
VCID: 21422AF881BB
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 132
Mileage: 212956 km
Time Indication: 0
Date: 2010.10.24
Time: 11:53:28
Coding: 0060021
VCID: 234E20F09BA7
End
So thanks for the all the replies!
Turns out that somehow after removing the ABS fuse and Right hand front door fuse I must have knocked another fuse.. Anyway, I pushed every single fuse in doubly yesterday and pop it all started working again.
I guess prehaps some of these devices are connected in serial and knocking one out knocks out several? I had performed a Optical Bus test and all perfomed OK, so it didn't appear to be a MOST problem.
The initial problem that prompted me to remove the door fuse was my heated mirror, mirror adjustment, automatic door closing and under handle lights have stopped working, so I wanted to check the fuse. Then something else prompted me to remove the ABS fuse as I've had some issues with the parking break recently.
Anyway, hopefully something useful for people to know..!
Cheers
Cheers
zipstic
01-23-2016 05:52 AM
ABS keeps coming on at extremely low speed stops. Any unforseen problems if I just pull the ABS fuse
EvanUrS4
05-11-2005 09:03 AM
