Replaced my instrument cluster today now MPG is stuck at 200.0 -
I picked up a brand new remanufactured cluster from the dealer for my '00 A6 4.2, set up the correct odometer mileage, activated the navigation code, but now the MPG is stuck at 200.0 and never changes. Is there something I missed or need to change in the adaption mode?
Please post part numbers from the old and new cluster. Also please double check if...
...the values in adaptation channels 60, 61 and 62 are OK.
Re: Please post part numbers from the old and new cluster. Also please double check if...
The values in adaptation channels of the new cluster are: #60: 1025, #61: 0, #62: 4
Unfortunately I never checked these numbers in my old cluster and it would be a real big pain in the A$$ if I had to reinstall the old cluster just to pull out these values. Are there standard codes for 60, 61, and 62 to turn on the MPG meter? or do I have to stick the old cluster back in?
---------------New Cluster----------------
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 4D0 907 558 S
Component: 4.2L V8/5V G 0008
Coding: 06652
Shop #: WSC 02325
No fault code found.
Address 02 -------------------------------------------------------
Controller: 4B0 927 156 BS
Component: AG5 01L 4.2l5V USA 1414
Coding: 00032
Shop #: WSC 02325
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00180
Shop #: WSC 02325
1 Fault Found:
01841 - Potentiometer/Actuator for Temperature Flap: Left (G220)
30-10 - Open or Short to B+ - Intermittent
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 4B0 907 487
Component: E Lenkrad Elektronik D03
VAG-COM
Self-Diagnosis Log
Wednesday, 20 September 2006, 15:45:20
Page 2
VIN Number: License Plate:
Address 17 -------------------------------------------------------
Controller: 4B0 920 980 MX
Component: C5-KOMBIINSTR. VDO D17
Coding: 03283
Shop #: WSC 00000
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15981
Shop #: WSC 02325
Address 36 -------------------------------------------------------
Controller: 4B0 959 760 A
Component: Sitzmemory D05
Address 37 -------------------------------------------------------
Controller: 4B0 919 887 E
Component: BNS 4.2 H05 BNO 0050
Address 45 -------------------------------------------------------
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
Address 55 -------------------------------------------------------
Controller: 4B0 907 357 C
Component: dynamische LWR D02
Coding: 00020
Shop #: WSC 02325
Address 56 -------------------------------------------------------
Controller: 4B0 035 195 A
Component: Radio D00
Coding: 00117
Shop #: WSC 40630
2 Faults Found:
00850 - Control Output Active: Radio Amplifier
29-10 - Short to Ground - Intermittent
00856 - Radio Antenna
36-00 - Open Circuit
End --------------------------------------------
-------------OLD CLUSTER-------------------
Coding: 06652
Shop #: WSC 02325
Coding: 00032
Shop #: WSC 02325
Coding: 0273004284
Shop #: BB 24334
Coding: 00180
Shop #: WSC 02325
Component: C5-KOMBIINSTR. VDO D09
Coding: 03283
Shop #: WSC 00000
VAG-COM
Self-Diagnosis Log
Sunday, 06 March 2005, 10:43:04
Page 2
Coding: 15981
Shop #: WSC 02325
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
Coding: 00101
Shop #: WSC 02325
Coding: 00020
Shop #: WSC 02325
Coding: 00117
Shop #: WSC 40630
1 Fault Found:
End -------------------------------------------------------
Coding: 06652
Shop #: WSC 02325
Coding: 00032
Shop #: WSC 02325
Coding: 0273004284
Shop #: BB 24334
Coding: 00180
Shop #: WSC 02325
1 Fault Found:
VAG-COM
Self-Diagnosis Log
Page 2
Coding: 03283
Shop #: WSC 00000
Coding: 15981
Shop #: WSC 02325
Coding: 00101
Shop #: WSC 02325
Coding: 00020
Shop #: WSC 02325
Coding: 00117
Shop #: WSC 40630
2 Faults Found:
Coding: 06652
Shop #: WSC 02325
Coding: 00032
Shop #: WSC 02325
Coding: 0273004284
Shop #: BB 24334
Coding: 00180
Shop #: WSC 02325
Coding: 03283
Shop #: WSC 00000
VAG-COM
Self-Diagnosis Log
Page 2
Coding: 15981
Shop #: WSC 02325
2 Faults Found:
35-00 - -
35-00 - -
Coding: 00101
Shop #: WSC 02325
Coding: 00020
Shop #: WSC 02325
Coding: 00117
Shop #: WSC 40630
1 Fault Found:
Great News...Problem Fixed..New Cluster works PERFECT!!!...
After much research, I found out that out that Audi did not equip the 2000 A6 4.2 model with either a Powertrain CAN (Ch 60)or Comfort CAN (Ch61) Databus. That year was only equipped with an Information CAN Databus(Ch 62) if it had either the navigation or telephone system installed at the factory.
When I pulled the adaptation codes from my new cluster, I noticed that there was a 1025 value for channel 60 (Powertrain CAN). So I changed that to a "0" and like magic the MPG was working again, displaying realistic numbers instead of 200.0 MPG.
jeffkruse
02-20-2015 07:02 AM
swift.
12
05-29-2007 06:45 PM
AudiForYou's 2.7T
07-29-2006 07:29 AM
