Repost in Correct forum :VAG-COM fault codes =(, easy fix or workshop repair?
hi,
I had a fault with the air con (econ light wont switch off) and an airbag light always on, ran VAG-COM, it returned this..
any help would be greatly appreciated
Car 2003 A4 1.8T quattro
btw, is all of Address 17 regarding the radio? if so ignore that, aftermarket radio.
Results..
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 518 AA
Component: 1.8L R4/5VT 0004
Coding: 0011701
Shop #: WSC 63351
1 Fault Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 008 - Implausible Signal - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04475
Shop #: WSC 06435
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
01810 - Actuating Motor for Temperature Flap: Right (V159)
41-10 - Blocked or No Voltage - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-10 - Open or Short to B+ - Intermittent
00819 - High Pressure Sensor (G65)
30-00 - Open or Short to B+
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
Address 15 -------------------------------------------------------
Control Module Part Number: 8E0 959 655 B
Component and/or Version: Airbag 8.4EP 2000
Software Coding: 0010602
Work Shop Code: WSC 63351
1 Fault Found:
01221 - Crash Sensor Side Airbag: Driver Side (G179)
012 - Electrical Fault in Circuit
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 F
Component: Lenks?ulenmodul 0308
Coding: 00011
Shop #: WSC 63351
Address 17 -------------------------------------------------------
Controller: 8E0 920 950 K
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 01400
Shop #: WSC 00636
WAUZZZ8E83A278285 AUZ6Z0B0292159
2 Faults Found:
01320 - Control Module for Climatronic (J255)
49-10 - No Communications - Intermittent
01304 - Radio
49-00 - No Communications
Address 45 -------------------------------------------------------
Controller: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 BD
Component: Komfortger?t TBF 1310
Coding: 06859
Shop #: WSC 63351
4 Faults Found:
01616 - Signal Wire to Interior Monitor
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
End -------------------------------------------------------
thank you for your time
barney
Results..
Coding: 0011701
Shop #: WSC 63351
1 Fault Found:
Coding: 04475
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
3 Faults Found:
Coding: 00001
Shop #: WSC 63351
1 Fault Found:
Coding: 00011
Shop #: WSC 63351
Coding: 01400
Shop #: WSC 00636
2 Faults Found:
01304 - Radio
Coding: 00001
Shop #: WSC 00000
Coding: 06859
Shop #: WSC 63351
4 Faults Found:
35-00 - -
35-00 - -
barney
barneya4b6
05-25-2006 12:06 AM
BSK
01-05-2005 01:43 PM
psyclobe
01-09-2004 10:02 PM
