Scanned my car with help from a friend on the VAG locator db
Scanned my car with some help from a local person that I found in the vag db, but neither of us were experts so I was wondering if some of you could help out with the diagnosis. Here are the symptoms:
Low power, low boost and the cel was triggering. A standard code scanner reported it as a misfire, but the vag tool detected it as 17746 (Camshaft position sensor).
I've had problems with the car since I purchased it three months ago. Stuttering/bucking/hesitation, it's only boosting 3psi instead of the standard 7-8, and it's extremely sluggish below 3k rpm, then it seems to pick up (but still only 3psi of boost).
I've replaced the plugs, one coil pack (which I diagnosed via trial and error), replaced the air filter, and replaced the dv with a 710n. Here are the codes and notes that we came up with:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8D0 907 557 P
Component and/or Version: 1.8L R4/5VT MOTR HS D06
Software Coding: 06201
Work Shop Code: WSC 06335
1 Fault Found:
17746 - Camshaft Position Sensor (G40) Open or Short to Plus
P1338 - 35-00 - -
Control Module Part Number: 8L0 862 257 N
Component and/or Version: CV-Pump D11
Software Coding: 16140
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to B+
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Control Module Part Number: 8E0 614 111 A
Component and/or Version: ABS/EDS 5.3 QUATTRO D10
Software Coding: 0273004284
Work Shop Code: BB 24334
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Control Module Part Number: 8D0 820 043 N
Component and/or Version: A4 KLIMAAUTOMAT D54
Software Coding: 00140
1 Fault Found:
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
1) Ignition timing at idle varies between 8-12* BTDC. -- Group 010.
2) No-load throttle angle @ idle = 3.9*. -- Group 010.
3) 2500 rpm throttle produces ignition timing 24* BTDC.
4) Part-throttle timing correction goes down to -7 CF when on the gas. Let off
the gas
and it goes down to -27 CF. -- Group 012.
5) Misfire recognition blocks set to "Disabled." -- Group 015, 016.
Knock Control = Group 020
Knock Sensor Voltages (Group 026): 0.628-O.785V, 0.628V, 0.7-1.0, 0.785
6) O2 Sensor Control (Group 088) varies between -3.0 - 3.0.
Wastegate Valve Duty Cycle = Group 114
Engine Actual Torque = Group 122
7) Crankshaft Pos Status = 0110000 -- Group 131
Driving notes:
Knock sensor voltages on all 4 cylinder banks = 2-6V part throttle and as much
as 20V at WOT.
Timing is being retarded by 6* on all cylinders.
Part- and full-throttle give ignition timing 24-32* BTDC.
I have a couple screen shots from the vag software that I'll try and put up soon. Any help that you can provide is greatly appreciated. Thanks!
1 Fault Found:
P1338 - 35-00 - -
9 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
28-00 - Short to B+
00955 - Key 1
00956 - Key 2
1 Fault Found:
1 Fault Found:
the gas
Driving notes:
as 20V at WOT.
Does any of the data indicate that the timing itself is off? Or should the replacement of the cps likely take care of it? It's due for a new timing belt/tensioner within 10-15k miles, and I'm just wondering if it might have jumped a tooth or something.
so, let's scratch my first thought in the post above. Yes, it's probably worth replacing the cam sensor.
First check voltage between pins 1 and 3 of the connector and make sure you have at least 4.5v with ignition turned on. If that's ok, and you're sure you don't have any wiring issues between the connector and the engine ECU, replace the sensor.
nickel4490
A4 (B7 Platform) Discussion
04-19-2010 09:14 PM
coocoomike
11-20-2002 08:18 PM
DanosS4
04-06-2002 01:51 PM
