Someone care to enlighten me to these changes?
Downloaded 512-1 and went to recode Cent Elec. Controller and noticed the coding was quite different from the numbers provided by Theresias. Appears to be multiple module choices for several different controllers in the car.
<img src="http://pictureposter.audiworld.com/24630/vagcomscreen.jpg">
...tell us exactly what you would like to change. I havn't checked the A8 stuff a while, so it's quite possible there have been some changes.
But I've never seen anything in the extras area of the contorllers before.
I looked over the A6 list and this is what I came up for the A8...not sure if its 100% correct with the Daytime Running light digits (5&6)
Controller coding STG 09 (electrical system)
select STG coding - function 07
0?xxxxx: Floor space lighting
0 - Floor space lighting as lamp blocks
1 - floor space lighting as LED blocks
0x?xxxx: Type of headlight
0 - Halogen headlight
1 - Bi-xenon-headlight
2 - Bi-xenon-headlight without LED DRL headlight
3 - Bi-xenon-headlight with LED DRL headlight and AFS II
4 - Bi-xenon-headlight with separate 21W halogen DRL and AFS II
0xx?xxx: Automatic Headlight
0 - without automatic headlight
1 - with automatic headlight with light sensor
3 - with automatic headlight with rain/light sensor
0xxx?xx: Day headlight
0 - without daily headlight
1 - with daily headlight
0xxxx?x: Kind of the day headlight
0 - without DRL
1 - with day headlight selectable over MMI (Default Value: AUS)
2 - with day headlight selectable over MMI (Default Value: EIN)
0xxxxx?: Land selection
1 - Remainder of the world the
2 - North Countries EU (Finland, Sweden, Norway)
3 - USA
4 - Canada
5 - Denmark
6 - Italy
0 - without DRL
3 - USA
4 - Canada
5 - Denmark
6 - Italy
...it appears that the old one is not complete, so I'm going to fix that. The 4E and 4F tables are not exactly the same, but they are similar. There was no real facelift of the 4E, they simply changed the grill, electronics havn't been changed much.
I know that not many electrical components have changed, but the instrument cluster, PDC, Central Electronics and Xenon Range definitely have changed for Facelift cars. With my previous version (510-x), I never saw anything in the extras or multiple modules in the controllers.
BTW I had translated several of the german pages to english and was going to send them until my hard drive crashed. I'll send them once I finish again.
VAG-COM Version: Release 512.1-UD
Saturday,04,March,2006,14:42:19
Chassis Type: 4E - Audi A8 D3
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 13 15 16 17 18 19 1D 1E 28
34 36 37 38 42 46 47 4E 4F 52 53 55 56 57 5E 61 62 65 66 67
VIN Number: WAUML44E46N006463
69 72 75 76 77
Address 01: Engine
Part No: 4E0 910 560 P
Component: 4.2L V8/5V G 0010
Coding: 0007773
Shop #: WSC 02313
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans
Part No: 4E1 910 156 E
Component: AG6 09E 4,2L5V USA 0060
Coding: 0000002
Shop #: WSC 02313
Address 03: ABS Brakes
Part No: 4E0 910 517 B
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 25807
Address 05: Acc/Start Auth.
Part No: 4E0 910 131
Component: FBS AUDID3 H07 0160
Coding: 0410624
Shop #: WSC 02311
Part No: XXX XXX XXX XX
Component: ELV XXXX
Address 06: Seat Mem. Pass
Part No: 4E0 910 760 D
Component: Sitzmemory BFS H01 0010
Coding: 0925792
Shop #: WSC 02313
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Address 07: Control Head
Part No: 4E0 910 731 B
Component: Interfacebox H43 1190
Coding: 0000003
Shop #: WSC 02313
Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Address 08: Auto HVAC
Part No: 4E0 910 043 B
Component: KLIMAAUTOMAT 016 0400
Coding: 0004417
Shop #: WSC 02311
Address 09: Cent. Elect.
Part No: 4E0 910 279 L
Component: ILM Fahrer H12 0210
Coding: 0143121
Shop #: WSC 02313
Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000034
Shop #: WSC 02313
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1
Part No: 4E0 910 111 E
Component: CD-Changer H44 0430
1 Fault Found:
02095 - Component Protection Active
000 - - - Intermittent
Skipping Address 15-Airbags
Address 16: Steering wheel
Part No: 4E0 910 549
Component: Lenks?ulenmodul H13 0040
Coding: 0012041
Shop #: WSC 02313
Component: Lenkradmodul H07 0080
Address 17: Instruments
Part No: 4E0 910 950 Q
Component: KOMBIINSTR. VDO H71 0400
Coding: 0048203
Shop #: WSC 02313
Address 19: CAN Gateway
Part No: 4E0 910 468 B
Component: Gateway H10 0080
Coding: FCFE7BDD1B7104
Shop #: WSC 02313
1 Fault Found:
01303 - Telephone Transceiver (R36)
Address 34: Level Control
Part No: 4E0 910 553 H
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 02313
Address 36: Seat Mem. Drvr
Component: Sitzmemory FS H01 0010
Coding: 0925802
Shop #: WSC 02313
Address 37: Navigation
Part No: 4E0 910 887 N
Component: MNS US H44 0740
1 Fault Found:
02261 - Media Player; Position 1 (R118)
014 - Defective - Intermittent
Address 38: Roof Electronics
Part No: 4E0 910 135 A
Component: Dachknoten D3 H02 0090
Coding: 0003477
Shop #: WSC 02313
2 Faults Found:
00457 - Control Module for Network (J519)
02282 - Sunroof Drive; Obstruction Detection
Address 42: Door Elect, Driver
Part No: 4E1 910 802 B
Component: T?rsteuer.FS BRM003 0100
Coding: 0032364
Shop #: WSC 02311
Address 46: Central Conv.
Part No: 4E0 910 289 B
Component: Komfortgeraet H05 0010
Coding: 0048702
Shop #: WSC 02313
Part No: 4E0 910 853
Component: Heckdeckel H06 0050
Part No: 4E0 907 719
Component: Neigungssensor H04 0020
Address 47: Sound System
Part No: 4E0 910 223 K
Component: DSP-Amp.-High H13 0440
Coding: 0000016
Shop #: WSC 02313
Address 4F: Centr. Electr. II
Part No: 4E0 910 280 A
Component: ILM Beifahrer H09 0040
Coding: 0010111
Shop #: WSC 02313
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass.
Component: T?rsteuer.BF BRM003 0100
Coding: 0032364
Shop #: WSC 02311
Address 53: Parking Brake
Part No: 4E0 910 801 C
Component: EPB A32C0220 H02 0220
Coding: 0000532
Shop #: WSC 02313
Address 55: Xenon Range
Part No: 4F0 910 357 C
Component: AFS 1 H01 0030
Coding: 0000018
Shop #: WSC 02313
Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio
Part No: 4E0 910 541 F
Component: TUNER EU/US/RDW H42 0480
Coding: 0000002
Shop #: WSC 02313
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground - Intermittent
Address 61: Battery Regul.
Part No: 4E0 910 181 C
Component: J0644 BEM H12 0550
Part No: 4E0 915 105 A
Component: von VA0 1506270005
Coding: 344530393135313035412056413031353036323730303035
Shop #: WSC 00000
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Address 62: Door,Rear Left
Part No: 4E0 910 802 A
Component: T?rsteuer.HL BRM003 0090
Coding: 0032364
Shop #: WSC 02311
Address 65: Tire Pressure
Part No: 4E0 910 273
Component: Reifendruck 2 H01 0280
Coding: 0212127
Shop #: WSC 02313
1 Fault Found:
02214 - Tire Pressure Warning
Address 67: Voice Control
Part No: 4E0 910 754 J
Component: SDS 3501 US H45 0600
Address 72: Door, Rear Right
Component: T?rsteuer.HR BRM003 0090
Coding: 0032364
Shop #: WSC 02311
Address 76: Park Assist
Part No: 4E0 910 283 C
Component: Parkhilfe 8-Kan H12 0020
Coding: 0201308
Shop #: WSC 02313
Address 77: Telephone
Part No: 4F0 910 336 B
Component: Handyvorb2 H11 0440
Coding: 0010900
Shop #: WSC 02313
End --------------------------------------------------------------------------------------------------
69 72 75 76 77
Address 01: Engine
Coding: 0007773
Shop #: WSC 02313
Coding: 0000002
Shop #: WSC 02313
Coding: 0007597
Shop #: WSC 25807
Coding: 0410624
Shop #: WSC 02311
Component: ELV XXXX
Coding: 0925792
Shop #: WSC 02313
1 Fault Found:
Coding: 0000003
Shop #: WSC 02313
1 Fault Found:
Coding: 0004417
Shop #: WSC 02311
Coding: 0143121
Shop #: WSC 02313
Coding: 00000034
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
Coding: 0012041
Shop #: WSC 02313
Coding: 0048203
Shop #: WSC 02313
Shop #: WSC 02313
1 Fault Found:
Coding: 0015510
Shop #: WSC 02313
Coding: 0925802
Shop #: WSC 02313
1 Fault Found:
Coding: 0003477
Shop #: WSC 02313
2 Faults Found:
Coding: 0032364
Shop #: WSC 02311
Coding: 0048702
Shop #: WSC 02313
Coding: 0000016
Shop #: WSC 02313
Coding: 0010111
Shop #: WSC 02313
Coding: 0032364
Shop #: WSC 02311
Coding: 0000532
Shop #: WSC 02313
Coding: 0000018
Shop #: WSC 02313
Address 56: Radio
Coding: 0000002
Shop #: WSC 02313
1 Fault Found:
Shop #: WSC 00000
1 Fault Found:
Coding: 0032364
Shop #: WSC 02311
Coding: 0212127
Shop #: WSC 02313
1 Fault Found:
Coding: 0032364
Shop #: WSC 02311
Coding: 0201308
Shop #: WSC 02313
Coding: 0010900
Shop #: WSC 02313
...I created one, but it has nothing more than coding info at the moment. It's planned to create some more files for the 4E in the near future.
Also you are right, there have been minor updates to the control modules, but these were the "normal" model year based changes, we are not talking about a real facelift here.
Anyway, the so called slaves modules are supported since VAG-COM version 510.0 and there have been some minor fixes to the extra field displaying too.<ul><li><a href="http://www.ross-tech.com/vag-com/download/label-files/4E0-910-279.lbl">http://www.ross-tech.com/vag-com/download/label-files/4E0-910-279.lbl</a</li></ul>
In this case, your 09-Cent.Elect. module has two codeable "Slaves", the Wiper module and the Rain & Light sensor.
You have to pick which one of them you want to code. The main module, or one of its slaves.
(Yes, I realize you've probably figured this out by now. I'm posting this to educate the casual reader).
-Uwe-
-Uwe-
http://www.Ross-Tech.com
<ul><li><a href="http://www.ross-tech.com/vag-com/download/label-files/4F0-910-357.lbl">http://www.ross-tech.com/vag-com/download/label-files/4F0-910-357.lbl</a</li></ul>
I've never noticed it before so it was odd to my eyes. Out of curiosity how is the BIM-COM coming along? I need to lower the rear suspension on my 760 and the dealers refuse to do it here.
