Swapped out ECU for an APR one and now getting code: 18057-
Data Bus Powertrain Missing message from ABS Control Module. It didn't have the code with the stock ECU and I can't clear it. ABS module shows no fault codes. The car is a 2001 A4 1.8tqm w/o ESP. Any ideas? The AW search is not working.
TIA
TIA
<center><img src="http://www.ross-tech.com/vag-com/tour/screens/4090/4090open.png"></center><p>
http://www.Ross-Tech.com
Then do I use the "Recode" button to try and change the new ECU soft coding to the same as the original one? I haven't had the VAG-COM for long, so I don't know how to use it very well, but I appreciate yours and Andy's help on this forum.
to check the coding to see if it's the same, yes. And if it's not the same, then you should recode the new one.
-Uwe-
-Uwe-
madchemistnj
VAG-COM Discussion
02-01-2006 03:54 AM
ch11
01-05-2003 05:20 PM
S Class
04-23-2002 06:49 PM
Ben3.2TT@BC
05-24-2001 10:24 PM
