TPMS Frequency change ?
Can VAG reprogram receiver frequency on the TPMS system?
I have an 07 D3 S8 which is setup at 315 mhz.
My winter wheels are from an 08 S6 with 433 mhz transmitters.
So TPMS warning is always popping up
Can the receiver be setup to the 433, or should I just
disable the TPMS?
thanks
disable the TPMS?
thanks
I think it can. For a definitive answer, please post scan data so we can see exactly what TPMS module is installed in your car.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Thanks for your help. Here is my first scan that I ran with my new VCDS
Error on the TPMS is related to the frequency .
(Winter wheels from 2009 S6) on my 07 S8
Is it possible to change receiver frequency or do I need to just disable TPMS?
Thanks
bbb
Sunday,30,December,2012,14:55:59:61825
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Chassis Type: 4L0
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 28 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN44EX7N012972 Mileage: 98190km/61012miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 A HW: 4E0 907 552
Component: 5.2L V10/4V FSI Ş0040
Revision: 5AH15--- Serial number: AUX3Z0FN711258
Coding: 01060009190F0160
Shop #: WSC 05146 444 84206
VCID: 204F25A0F3326218015
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI USA 0030
Revision: --H01--- Serial number: 0098305
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2B55C28C8AF4B140A47
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H46 0500
Coding: 0001627
Shop #: WSC 02313 000 00000
VCID: 244729B0E72A7E3865D
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0FN711258
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BFCD406BE26AD8B95
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 6
Reset counter: 200
Mileage: 96640 km
Time Indication: 0
Date: 2012.11.23
Time: 13:00:38
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348L%067508782
Coding: 0000003
VCID: 3365DAEC52C4E980EC7
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000110634
Coding: 0106833
VCID: 1C371150DF5A46F8DDD
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133123
VCID: 3663E3F841B6FCA8CB9
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBF3108778
Shop #: WSC 00000 000 00000
VCID: 1A3B1748D56E38C8CF1
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0027586
VCID: 2C57C1908FFAB678ADD
Address 11: Engine II Labels: Redir Fail!
Shop #: WSC 05146 444 87968
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0G010MW
Coding: 0532707
VCID: 264333B891168C287B9
Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012141
VCID: E5C1F4B42C90C730323
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 F HW: 4E0 920 951 F
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3FD000649
Coding: 0048263
Shop #: WSC 23890 444 11078
VCID: 285F3D809B029A58495
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06B1180A8
Coding: F5F5DFFF307A0E
Shop #: WSC 05146 444 59366
VCID: ECD78190CF7AF6786DD
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000048447
Coding: 0000000
VCID: E1C9E0A438B8AB10CEB
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A5BC788850EA8485F1
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 L
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381K$067515389
VCID: 387FEDC04BA20AD8D95
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000630400065
Coding: 0003477
VCID: 1D311C54C4404FF02A3
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040612040082
Coding: 0048702
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 D HW: 4E0 035 466
Component: BO_D3 H06 0320
Revision: 20S00002 Serial number: 00911060006581
Coding: 0000026
VCID: 275D3EBC961C952040F
Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000003375
Coding: 0010111
VCID: 1E331B58C94654E8339
Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000732
Shop #: WSC 23890 444 82910
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 295938848008A35056B
Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396K1067556158
Coding: 0000002
VCID: 3169D0E4A8D8DB909EB
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000025603
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 39100660U4
Coding: 344530393135313035412056413033393130303636305534
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Mileage: 94494 km
Time Indication: 0
Date: 2012.10.19
Time: 20:31:00
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 94494 km
Time Indication: 0
Date: 2012.10.19
Time: 20:34:26
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 94494 km
Time Indication: 0
Date: 2012.10.21
Time: 09:55:20
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 94494 km
Time Indication: 0
Date: 2012.10.21
Time: 09:55:22
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 94494 km
Time Indication: 0
Date: 2012.10.21
Time: 09:55:32
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900048883
Coding: 0232428
1 Fault Found:
01521 - Sensor for Tire Pressure
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 44
Reset counter: 0
Mileage: 97980 km
Time Indication: 0
Date: 2012.12.26
Time: 07:48:07
Freeze Frame:
(no units): 64.0
Temperature: 2.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000611100063
Shop #: WSC 12336 024 394758
VCID: 3467D9F057CAEEB8F5D
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6X108M
Coding: 1121402
VCID: DCB7D1501FDA86F89DD
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720632300046
Coding: 0221208
VCID: 23452AACE22479001C7
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007572449
Coding: 0010900
End ---------------------------------------------------------------------
Uwe
Looks like it is setup at 433 mhz (I believe that is what the coding indicated)
Will research a bit more, try the 315 mhz setup, and if that fails to solve the issue, just disable the tpms until my summer wheels go back on.
Thanks
Thanks
kem
NorCal Discussion
12-21-2007 10:46 AM
