TPMS (tire pressure) disable on A4 B8
Hello,
I tried to disable this via Address 17, Channel 61, Subtract 512. Unfortunately channel 61 and 65 suggested in another post didn't have anything and just showed an error.
Anyone know yet what the TPMS disable is then for an A4 B8 and it sounds like the A5 as well?<ul><li><a href="https://forums.audiworld.com/rs4b7/msgs/64135.phtml">Link to posting on 'old' instructions for TPMS disable</a></li></ul>
Okay, the coding for #17 is...
831F09000700D705020000
I had already adjusted the first bit to remove the seat belt chime, so it is not the default.
In looking through some of the other postings, I tried modifying the code to the following but I did not see any difference.
831F09000600D705020000
then
831F09000B00D705020000
831F09000A00D705020000
831F09000900D705020000
831F09000800D705020000
831F09000500D705020000
831F09000400D705020000
831F09000300D705020000
I see that you were wanting to know more information from the individual with the A5. Unfortunately I don't know what else would help you, so I'll try to put down some more details.
This is a B8 A4 that was just received about a month ago. In the vag for #17, I hit the "ID" button to get the following information, which I hope is helpful in describing more about what VAG-COM is seeing...
Thursday,04,December,2008,19:42:19:03942
VCDS Version: Release 805.1
Address 17: Instruments
Control Module Part Number: 8K0 920 980 F
Component and/or Version: KOMBIINSTR. H16 0221
Software Coding: 831F09000700D705020000
Work Shop Code: WSC 02399
Advanced Identification
Serial number: [removed for posting]
Identification: MY2-COR
Revision: 00200000
Date: 16.07.08
Manufacturer number: 0103
Test stand number: 3075
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Attempts(data): 0
Successful Attempts(data): 0
Programming Status: 00000000
Flash Date: 2008.02.08
Flash Tool Code: 00000 000 00000
Flash Tool Code(data): 00000 000 00000
Software
Theft prot.:030203
BAP:010300
CAN:011200
TP 2.0:030400
KWP2000:030000
OSEK-OS:033700
HiSpd Net:010600
Misc.
Hardware number: 8K0 920 980 F
Workshop System Name: J285
ASAM Dataset: Unknown
ASAM Dataset Revision: Unknown
then
Revision: 00200000
Date: 16.07.08
Flash Status
Software
Theft prot.:030203
BAP:010300
CAN:011200
TP 2.0:030400
KWP2000:030000
OSEK-OS:033700
HiSpd Net:010600
Misc.
I must say the tmps failure notification is not as bad as I thought it would be. If someone figures out the vag setting I'll do it but I really won't go out of my way to deal with it.
Yeah, my friend says it is not horrible either, just a slightly annoying at first when it beeps at you.
That being said, I'd still be willing to try any vag hacks that we haven't tried already to see if we can solve this.
mtl expos RIP
10-10-2002 09:31 AM
jxalho
02-18-2000 02:58 AM
