Tranny recode 00032 not working...
Just got my Ross-Tech VAG-COM, so went to recode my tip with 00032 based on all the great things I've heard.
I entered in new code and checked that it was there.
Test drive did not allow steering wheel radio buttons to be used for tip shifting. Tranny seemed to be working as before the recode. After test drive I verified that code 00032 was still present which it was.
Any suggestions.
Any suggestions.
no auto-shift from 1 to 2. stock, it will automatically shift a little after 2000rpm unless you give it 3/4 throttle or more. with this recode, it will stay in first no matter what until redline.
that said, just did that recode for someone a week ago and they didn't see the behavior...they still needed to give healthy throttle in order to keep first (his and my cars are S4's).
present" or not. The functional activation depends on the firmware version of the TCU, and or thr PN.
Others have had success activating "Tip in D" with the multifunction SW and paddles only steering wheels, by recoding the TCU and or Steering Column Control Module, on B6 A4 3.0l tips, and on A6 tips.
Question: I just retrofitted an MSFW with Tip buttons on my 03 allroad (along with MFSW controller 618) - the controller is coded for Tip Buttons but they are not working
My tranny code is 01002
Do I need to change it to 01032 for the tip buttons to work?
it'll either accept it enable that function, accept it and not enable that funtion, or not accept it (speaking in general for vag-com). don't worry about blowing anything up is what i'm trying to say; give it a shot.
