Transmission issues Tiptronic A4
Got a 98.5 A4 TIP 1.8T Quattro
Yesterday when starting the car i went to go in reverse, nothing, the light on the dash for R wouldnt light up. SO i messed around and got it to go in once in a while. I ran VAG and got no error codes.
so, today i took another stab at it and finally it went into limp home mode, leaving me without 5th gear, but everyother gear works including reverse. I checked again with VAG and got the following for the Tranny
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8D0 927 156 BJ
Component and/or Version: AG5 01V 1.8l5VT USA 7812
Software Coding: 00000
Work Shop Code: WSC 00000
1 Fault Found:
00293 - Multi-function Switch (F125)
27-10 - Implausible Signal - Intermittent
I have searched on this matter, and have found that it is most likely the F125 switch that looks like a PITA to replace, so before doing it i decided to get some opinions.
any help would be appreciated
1 Fault Found:
the range switch on the left side of the transmission is the likely culprit...
I've done quite a few, and they're not really that bad to do. Just need to be able to support the transmission so you can take the mount off to get to the part.
Just Incredible B6S4
VAG-COM Discussion
05-23-2008 10:35 AM
NiceS4
08-30-2007 10:07 AM
