Triple Light Syndrome on an allroad (ESP, ABS, LEVEL) UPDATED WITH FULL SCAN
HERE IS THE SCAN BELOW:
I have heard it can be the following,(Thanks Paulroad):
1)ABS CONTROL MODULE
2)STEERING ANGLE SENSOR
3)BRAKE PEDAL SWITCH
I scanned it last week, and I missed the 01772- Signal from the Level Control Pressure Sensor code...
My thought is that when I put on new wheels and 402'd it, the pressure dropped in the Left Front for a minute and knocked something loose?
What could that be? I have looked on the back of the wheel/brake and checked things by hand, and everything seems ok, but I'm no expert and don't know what to look for.
Any help would be so greatly appreciated.
Wednesday,28,June,2006,17:14:17
VAG-COM Version: Release 512.4-UD
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 67 75 76
77
VIN Number: WA1YD54B82N089574
Address 01: Engine
Part No: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
WA1YD54B82N089574 AUZ7Z0A1982087
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans
Part No: 4Z7 927 156 F
Component: AG5 01V 2.7l5VT USA 1818
Coding: 01002
Shop #: WSC 02325
Address 03: ABS Brakes
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06397
Shop #: WSC 00000
1 Fault Found:
18036 - Powertrain Data Bus: Missing Message from Steering Angle Sensor
P1628 - 35-00 - -
Address 08: Auto HVAC
Part No: 4B0 820 043 AL
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 01505
Skipping Address 15-Airbags
Address 17: Instruments
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 06264
Shop #: WSC 06449
Address 34: Level Control
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
2 Faults Found:
01316 - ABS Control Module
79-00 - Please Check Fault Codes
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D35
Coding: 15885
Shop #: WSC 02325
Address 55: Xenon Range
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00030
Shop #: WSC 02325
Address 56: Radio
Part No: 4B0 035 195 J
Component: symphony II NP2 0008
Coding: 00201
Shop #: WSC 00003
End --------------------------------------------------------------------------------------------------
77
Address 01: Engine
Coding: 06752
Shop #: WSC 02325
Coding: 01002
Shop #: WSC 02325
Coding: 06397
Shop #: WSC 00000
1 Fault Found:
P1628 - 35-00 - -
Coding: 00010
Shop #: WSC 01505
Coding: 06264
Shop #: WSC 06449
Coding: 25500
Shop #: WSC 09999
2 Faults Found:
Coding: 15885
Shop #: WSC 02325
Coding: 00030
Shop #: WSC 02325
Address 56: Radio
Coding: 00201
Shop #: WSC 00003
before you said it wasn't 402 or level control related, but now I have a Level Control Pressure Sensor code, that I may have cleared the first time I hooked up the VAG...
Thoughts???
Thoughts???
Mike Ragan
VAG-COM Discussion
11
07-09-2019 06:50 PM
iNfiNkC
03-16-2007 03:25 PM
