Turn door chime off?
Search didn't help- got the seatbelt chime off thank God-now want to turn off the door chime as well but can't find it in module 17 where the seatbelt chime is... which module is it in? TIA.
Come on guys- someone has done this... I find one option in Drivers door electronics , module 42, that says safety feature enable +000256. Wonder if that's it, but I'm not about to just start "trying" things! Could subtract that number and try it, but...
It's a '06 A8 SWB sport- by auto scan, you mean the one that goes thru all the systems looking for faults? I'm afraid I'm too much of a computer illiterate to know how to post that once I've done it... Did that a couple days ago before I got rid of the seatbelt chime and the only fault it found was lo battery in one of the keys, and that was last year...
Audiworld Premium Sponsor
from the VCDS manual:
To paste, you can just press the CTRL key and at the same time press the "v" key. That will paste the copy into the window you want to paste it in.
For a better understanding, watch Jef's Youtube Tutorial on Autoscans:
http://www.youtube.com/watch?v=4jt3l...ayer_embedded#!
Without the autoscan, it's doubtful we will be able to help you.
Results:
The output from looks like this autoscan-result-A5-8035.txt
If you close the Auto-Scan dialog, any data in its output box will be lost. If you would like to keep a record, click the [Copy] button first, then you can paste the results into the application of your choice, such as MS Word or Notepad.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
VCDS Version: Release 10.6.0
Data version: 20100630
Tuesday,10,August,2010,21:04:50:41562
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAULL44E16N023670 Mileage: 107550km/66828miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0F2789047
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E588208C07F
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0081678
Coding: 0000002
VCID: 254A7D249589
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 2240663884A7
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F2789047
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B484D0127B
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 00000 785 00200
VCID: 244C60209EB3
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 346CJ067531711
Coding: 0000003
VCID: 20446C308AAB
Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000093064
Coding: 0004417
VCID: 1C3C58C0A6C3
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 3668AA68382F
Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH12 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7273138
Shop #: WSC 00000 000 00000
VCID: 1B3E5BDCA3CD
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
Component: SDAR
Revision: 0000000 Serial number: AUZ4Z7E40
VCID: 29527114F991
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0005E0C
Coding: 0532707
Shop #: WSC 05811 444 54714
VCID: 26487A28E88F
Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: E5CABD245509
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3F2004047
Coding: 0048203
Shop #: WSC 02320 444 53920
VCID: 32609678D447
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 200030632380E1
Coding: FCFE7BDD1B7904
VCID: 2756772CEF85
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
VCID: D8B484D0127B
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A508E18FC97
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
VCID: 244C60209EB3
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 F HW: 4E0 919 887 C
Component: MNS US H45 0990
Revision: 00000000 Serial number: 355CW067564763
VCID: 31629974D141
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H04 0090
Serial number: 00000606500021
Coding: 0003477
VCID: 1D3A55C4BDD9
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
VCID: 20446C308AAB
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040603090286
Coding: 0048766
VCID: 28547410E29B
Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000007845
Coding: 0000016
VCID: 2A508E18FC97
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000080598
Coding: 0010111
VCID: 1E3852C8B0DF
Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
VCID: 20446C308AAB
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 02326 444 83476
VCID: 20446C308AAB
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 28547410E29B
Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396CV067534625
Coding: 0000002
VCID: 234E633C9BBD
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000004315
Shop #: WSC 03751 444 54648
VCID: 20446C308AAB
Part No: 4E0 915 105 A
Component: von VA0 1603290225
Coding: 344530393135313035412056413031363033323930323235
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
VCID: 1E3852C8B0DF
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900037729
Coding: 0232125
VCID: DFC6AFCC7755
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000603100183
Shop #: WSC 12336 024 394758
VCID: 2D5A8504CD79
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
VCID: 1E3852C8B0DF
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720608602822
Coding: 0201208
VCID: 234E633C9BBD
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007536176
Coding: 0010900
VCID: 2240663884A7
End ---------------------------------------------------------------------
Just did this autoscan- hope it helps. TIA
Chassis Type: 4E0
Coding: 0007773
VCID: 2E588208C07F
Coding: 0000002
VCID: 254A7D249589
Coding: 0008597
VCID: 2240663884A7
Coding: 0410624
VCID: D8B484D0127B
Component: ELV XXXX
Coding: 4071520
VCID: 244C60209EB3
Coding: 0000003
VCID: 20446C308AAB
Coding: 0004417
VCID: 1C3C58C0A6C3
Coding: 0143123
VCID: 3668AA68382F
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
VCID: 1B3E5BDCA3CD
Component: SDAR
VCID: 29527114F991
Coding: 0532707
VCID: 26487A28E88F
Coding: 0012141
VCID: E5CABD245509
Coding: 0048203
VCID: 32609678D447
VCID: 2756772CEF85
Coding: 0410624
VCID: D8B484D0127B
Component: ELV XXXX
Coding: 0015510
VCID: 2A508E18FC97
Coding: 4071530
VCID: 244C60209EB3
VCID: 31629974D141
Coding: 0003477
VCID: 1D3A55C4BDD9
Coding: 0032364
VCID: 20446C308AAB
Coding: 0048766
VCID: 28547410E29B
Coding: 0000016
VCID: 2A508E18FC97
Coding: 0010111
VCID: 1E3852C8B0DF
Coding: 0032364
VCID: 20446C308AAB
Revision: --H03---
Coding: 0000532
VCID: 20446C308AAB
Coding: 0000018
VCID: 28547410E29B
Coding: 0000002
VCID: 234E633C9BBD
VCID: 20446C308AAB
Coding: 0032364
VCID: 1E3852C8B0DF
Coding: 0232125
VCID: DFC6AFCC7755
VCID: 2D5A8504CD79
Coding: 0032364
VCID: 1E3852C8B0DF
Coding: 0201208
VCID: 234E633C9BBD
Coding: 0010900
VCID: 2240663884A7
I dug through that scan and I don't see any way to disable the door ajar chime.
Some vehicles will change this behavior when the instrument cluster country coding is changed, however on a vehicle like this I don't know what the other consequences may be, so I would not recommend doing that.
Thanks for looking but I could swear I've heard of others getting rid of all the chimes- maybe it wasn't a newer D3 A8... and I was looking forward to sitting in the car playing with the computer on my lap with a heat index of 105...
larryV
Q5/SQ5 MKI (8R) Discussion
12
05-15-2017 11:08 AM
BakerCoupe
03-01-2006 01:47 PM
