Turn off Brakepad Wear Sensor?
I swapped the stock pads for racing pads and have the brake pad sensor lit up on my dash. I bought vag-com to disable it. I was able to find the page for the Golf 5 platform (I assume that is my car's platform since I was able to use the micro-cam interface). According to the instructions on that page I should have been able to turn off the brakepad wear sensor by subtracting 1 from the soft coding changing it from 0049268 to 0048268 but it was a no go. Any suggestions?
The wear sensor is just a wire in your brake pad that is broken (open circuits) when wear limit is reached.
Bruce
Bruce
It seems likely that no configurations of your car were sold without wear sensors. You may want to install a jumper at the brake pad wear sensor connection since, per the label file, I don't see any Coding options that would allow you to remove the brake pad wear sensor monitoring:
C00,Instrument Cluster (J285) Coding
C01,????xxx: Equipment
C02,+0001 = 2nd Fuel Tank Characteristic (All-Wheel Drive)
C03,+0002 = Highline without DIS (for Midline PR-9Q3)
C04,+0004 = Manual Transmission (not Midline PR-9Q3)
C05,+0008 = 2nd Tire Circumference Pair (e.g. Winter Tires)
C06,+0016 = Tire Pressure Monitoring (TPMS)
C07,+0032 = AFS (Advanced Front Lighting System (cornering lights)
C08,+0064 = Magnetic Ride Suspension
C09,xxxx?xx: Country
C10,0 = Germany / 1 = Rest of World (RoW - Left Hand Steering) / 2 = USA / 3 = Canada
C11,4 = Great Britain (Right Hand Steering) / 5 = Japan (Left Hand
Steering) / 6 = Arabien States
C12,7 = Australia / 8 = Rest of World (RoW - Right Hand Steering) / 9 = Japan (Right Hand Steering)
C13,xxxxx?x: Seatbelt Warning
C14,0 = No Seatbelt Warning / 1 = Seatbelt Warning (EU-NCAP) / 2 = Seatbelt Warning (NAR Old)
C15,3 = Seatbelt Warning (NAR New) / 4 = Seatbelt Warning (EU-NCAP incl.
Passenger)
C16,5 = Seatbelt warning (NAR Old incl. Passenger) / 6 = Seatbelt Warning (NAR New incl. Passenger)
C17,xxxxxx?: Illumination & Washer Fluid Warning C18,0 = Needles OFF and Scales OFF (Term. 15 ON / Term. 58 OFF) / 1 = Needles ON and Scales OFF (Term. 15 ON / Term. 58 OFF)
C19,2 = Needles OFF and Scales ON (Term. 15 ON / Term. 58 OFF) / 3 = Needles ON and Scales ON (Term. 15 ON / Term. 58 OFF)
C20,+4 = Washer Fluid Warning
Regards,
Andy
Passenger)
Regards,
Andy
CarNut68
Audi Original "S" Cars
12-08-2008 10:47 PM
Biscuit141
06-10-2003 10:51 AM
JDreher
02-11-2003 07:20 AM
YHL
03-12-2001 05:55 PM
