Unknown DTC in wiki
Is there anywhere I can get information about 17416? Nothing in the wiki. What would the implausible signal be? These are new Bosch MAFs that I installed today.
Code:
Monday,15,March,2010,21:48:26:19387 VCDS Version: Release 908.1 Address 01: Engine Labels: 077-907-558-BCY.LBL Control Module Part Number: 4D1 907 558 Component and/or Version: 4.2l V8/5VT G 0002 Software Coding: 0010752 Work Shop Code: WSC 00000 4 Faults Found: 17535 - Fuel Trim; Bank 1 (Mult): System too Rich P1127 - 002 - Lower Limit Exceeded - Intermittent 17544 - Fuel Trim: Bank 1 (Add): System too Lean P1136 - 001 - Upper Limit Exceeded 17546 - Fuel Trim: Bank 2 (Add): System too Lean P1138 - 001 - Upper Limit Exceeded 17416 - Mass Air Flow Sensor 1/2: Implausible Signal P1008 - 008 - Implausible Signal - Intermittent Readiness: 0010 1101
Although there's not much available regarding this code, I would expect that the ECU is unhappy about a difference in signal between the two MAFs. You might want to find the live readings for the two MAFs in the Measuring Blocks and take a look at what the ECU is actually seeing from each of them.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
In response to fault "P1008" the two air mass meters are not checked for mutual plausibility by the engine control unit as might be expected. Instead, the two air mass meter signals are summated and then compared to a map value in the engine control unit. Fault "P1008" is detected if the sum total of the two air mass meters is outside a tolerance range.
Got it started. Where did you find that explanation?
http://wiki.ross-tech.com/wiki/index.php/17416/P1008
pkvoss
01-31-2009 05:49 PM
rktskicar
23
09-12-2008 08:37 PM
