VAG Codes
I don't really understand the codes but I got my car VAG'd to find out why the Traction Control (ESP), ABS and brake lights are on when I am driving. Maybe someone on this forum would have more insight and could assist me as to where and/or what needs to be fixed. Here are the main issue reported from the read out:
Control Module Part Number: 8D0 907 551 AA
Component and/or Version: 2.7l V6/5VT G 0003
Software Coding: 06751
Work Shop Code: WSC 63351
4 Faults Found:
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 35-10 - - - Intermittent
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
VAG-COM Version: Release 504.1-UD
Control Module Part Number: 8D0 907 389 E
Component and/or Version: ABS/ESP allrad D56
Software Coding: 00000
Work Shop Code: WSC 00000
2 Faults Found:
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
Anybody have any ideas?
4 Faults Found:
P1423 - 35-00 - -
P1411 - 35-00 - -
2 Faults Found:
35-00 - -
CrazyINP-12V Ivan
01-18-2007 08:54 AM
Vtec_Killer
11
08-26-2003 08:50 AM
