Vag-Com Autoscan Printout ***FEEDBACK NEEDED***
VAG-COM
Monday, 09 October 2006, 16:16:57
Mileage: 99460
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,17,25,35,45,56
Address 01 -------------------------------------------------------
Controller: 3B0 907 551 BA
Component: 2.8L V6/5V G03 0003
Coding: 07251
Shop #: WSC 02325
2 Faults Found:
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 35-00 - -
16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
P0431 - 35-00 - -
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
01842 - Potentiometer/Actuator for Temperature Flap: Right (G221)
30-10 - Open or Short to B+ - Intermittent
Mileage: 99460
Coding: 07251
Shop #: WSC 02325
2 Faults Found:
P0421 - 35-00 - -
P0431 - 35-00 - -
Coding: 00160
Shop #: WSC 02325
2 Faults Found:
looks like you need a pair of cats, which if you're within.....
8 yrs/80k miles from new, you should be covered, unless you're insanely modded.
As far as the climate control goes.....is there a noticable problem and have you run basic settings?
Dealer *may* have a flash update for your ECU which can fix the CAT codes
Since you're out of the Federal emissions warranty, it won't be free, but even if you pay them for it (should be ~1 hour), it's WAY cheaper than new CATs.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Pete K (vegasguy)
VAG-COM Discussion
12-13-2007 02:10 PM
barneya4b6
05-25-2006 12:06 AM
iProDrive
VAG-COM Discussion
04-20-2006 01:15 PM
