VAG-Com 'Can't synch Baud Rate' problem
I bought a non RossTech KKL-USB interface cable to see why I get frequent 'Emissions Workshop' warning lights. Running the free version 409.1 I can see the ABS controller, read temperatures, steering wheel angle etc but cannot connect to the engine controller and get the Can't Sync Baud rate message.
Below is the data file it created
I have posted this question because I could not get the forum archive search to work.
Ian
VAG-COM Version: Release 409.1-US
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
Controller:
Note: Can't Synch Baud Rate
Address 03: ABS Brakes
Controller: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0011266
Shop #: WSC 01271
No fault code found.
Ian
Address 01: Engine
Controller:
Coding: 0011266
Shop #: WSC 01271
<ul><li><a href="http://ross-tech.com/vag-com/faq_2.html#2.4">http://ross-tech.com/vag-com/faq_2.html#2.4</a</li></ul>
The engine is a 1.6L petrol
I have read and acted upon the tips given in the FAQ but still cannot read the engine contoller.
Wow that really narrows it down. Do you have any idea how many different "1.6L Petrol" engines VW has made?
Try Options -> Start Baud = 9600.
If that doesn't so it, contact your hardware vendor for assistance.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Actually I did not have any idea how many differeny 1.6L petrol engines there are.Thanks for your help anyway, I will try the 9600 setting you mentioned although I did not notice that option in the USB settings but will look next time I get the car back from the garage!
Basically I took the car to a local garage who read the code (intermittent missfire on cylinder 2) and so did a compression test which points to valve fault on that cyl. 44,000 miles and of course just out of warranty!
Thanks once again
Ian P
Thanks once again
Ian P
Ian
Address 01: Engine
Controller:
Coding: 0011266
Shop #: WSC 01271
Ian
Address 01: Engine
Controller:
Coding: 0011266
Shop #: WSC 01271
I have the same problem. Do you have the solution of this issue?
