vag com codes help-radio shuts off
I've only owned the car for about a month. Many electrical probs since. Including esp module replaced. Short in e-brake wire under middle console.(both fixed) Now, my symphonyII Bose HU sporadically flickers then shuts off and on very randomly, whether idling of moving. Ordered new radio, tried it and the same. Also, both rear door locks started sporadically not unlocking. Not usually when rolling, more when car is sitting and not running. Here is the vag com report. Please help, on what might be the cause of this. The single wire, has me scratching my head..........thinking maybe a short somewhere.
Anyone, please!!!!
Wednesday,30,May,2012,19:19:43:30504
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WA1YD64B35N018437 Mileage: 91630km/56936miles
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 T
Component: 2.7L V6/5VT G 0010
Coding: 07755
Shop #: WSC 02334
VCID: 54AD57CCA4E06E9
WA1YD64B35N018437 AUZ7Z0D2686480
2 Faults Found:
17866 - Exhaust Gas Temp Sensor 2 (G236)
P1458 - 35-10 - Short to Ground - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 T
Component: AG5 01V 2.7l5VT USA 0505
Coding: 0001002
Shop #: WSC 00000 000 00000
VCID: 57B7A0C0E516451
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06497
Shop #: WSC 02334
VCID: 4A9149B476A4289
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 N
Component: Airbag 8.4EP 1000
Coding: 0000607
Shop #: WSC 02334 785 00200
VCID: 5AB1B9F49604589
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02334
VCID: 2F673820ED066D1
2 Faults Found:
01305 - Databus for Infotainment
37-10 - Faulty - Intermittent
80-00 - Single-Wire Operation
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 F
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 04364
Shop #: WSC 94708
VCID: 2B5F2C30D91E111
2 Faults Found:
01304 - Radio
49-10 - No Communications - Intermittent
01311 - Information Data Bus
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 02334
VCID: 489573BC68A8DA9
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 94708
VCID: 336F3450012E491
7 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
01562 - Right Rear Door
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
VCID: 2C5D2F2CDC10169
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02334
VCID: 040DA78C14003E9
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 4B0 035 195 N
Component: symphony II PM6 0410
Coding: 00205
Shop #: WSC 07936
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-00 - Open Circuit
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 02334
VCID: 0201A1940E14309
End ---------------------------------------------------------------------
Anyone, please!!!!
75 76 77
Coding: 07755
Shop #: WSC 02334
2 Faults Found:
Coding: 0001002
Coding: 06497
Shop #: WSC 02334
Coding: 0000607
Coding: 01002
Shop #: WSC 02334
2 Faults Found:
Coding: 04364
Shop #: WSC 94708
2 Faults Found:
01304 - Radio
Coding: 25500
Shop #: WSC 02334
1 Fault Found:
Coding: 15885
Shop #: WSC 94708
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00030
Shop #: WSC 02334
Coding: 00205
Shop #: WSC 07936
1 Fault Found:
Coding: 01186
Shop #: WSC 02334
Anyone, please!!!!
75 76 77
Coding: 07755
Shop #: WSC 02334
2 Faults Found:
Coding: 0001002
Coding: 06497
Shop #: WSC 02334
Coding: 0000607
Coding: 01002
Shop #: WSC 02334
2 Faults Found:
Coding: 04364
Shop #: WSC 94708
2 Faults Found:
01304 - Radio
Coding: 25500
Shop #: WSC 02334
1 Fault Found:
Coding: 15885
Shop #: WSC 94708
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00030
Shop #: WSC 02334
Coding: 00205
Shop #: WSC 07936
1 Fault Found:
Coding: 01186
Shop #: WSC 02334
Anyone, please!!!!
75 76 77
Coding: 07755
Shop #: WSC 02334
2 Faults Found:
Coding: 0001002
Coding: 06497
Shop #: WSC 02334
Coding: 0000607
Coding: 01002
Shop #: WSC 02334
2 Faults Found:
Coding: 04364
Shop #: WSC 94708
2 Faults Found:
01304 - Radio
Coding: 25500
Shop #: WSC 02334
1 Fault Found:
Coding: 15885
Shop #: WSC 94708
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00001
Shop #: WSC 00000
Coding: 00030
Shop #: WSC 02334
Coding: 00205
Shop #: WSC 07936
1 Fault Found:
Coding: 01186
Shop #: WSC 02334
ngr5011
04-05-2008 05:41 PM
