Vag-com engine>measuring block
Hi all
Newbie here so please be patient and go easy on me![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
I am currently having problems with my A5, I received my vag-com today (cool bit of kit) but I am having problems access the measuring blocks section from the engine module. It is currently greyed out and cannot be accessed.
The only option I can access is advanced measuring blocks but from some of the guides I have seen online I do need access to the basic measuring blocks option.
Can anyone advise me further please?
Audiworld Premium Sponsor
Your car uses the UDS protocol. There are no standard measuring values which is why the 08 function is grayed out. All are done using the Advanced Measuring Values. See: http://www.ross-tech.com/vcds/tour/adv-meas-blocks.html and in particular pay attention to the sentences about UDS/ODX/ASAM protocol
Basic Settings are also performed using UDS. Basic Settings in UDS appear as drop down options. Again I point you to the manual but to the Basic Settings section: http://www.ross-tech.com/vcds/tour/b-settings.html and again, pay attention to the sentences about UDS/ODX/ASAM protocol
What exactly are you trying to do?
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
Thanks for the answers its appreciated.
I need to try a throttle body alignment also a DPF regeneration. But the guides I have read say I need access to basic measuring blocks. So unless I can access the basic option I dont think I can do either?
Basic Settings (as already stated) and Adaptations are done through a drop down box found in those areas of the controller. It is possible, as we say in the manual to which I pointed you, that your car is so new that VCDS does not have the label file for your control module.
Without a full autoscan from your car, I can't really crystal ball what you need to do. Just telling us I have an A5 - tells us just about nothing by which we might be able to assist.
Post an autoscan and maybe we can direct you further.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
You do not state if the car is new or used, and so since you are DIY, I am going to assume that you have a used car that is no longer under warranty... If you have a MIL on and the VAG-COM says you need to perform Throttle Adaptation, then it is simple... follow the Ross-Tech instructions for a UDS system as pointed out by earlier reply...
If you have other DTC's such as MAP/MAF Throttle Correlation problems and Low Air Flow... then the throttle body plenum plate is sticking to the wall of the TB and does not open at the specified angle for the gas peddle input, and those errors will continue until you clean that up...
Take the air hose off and push against the plenum... you can feel it sticking to the wall... if this is the case, just spray a small amount of carb cleaner along the edge and work the plenum flap until it doesn't stick to the wall...
Hope this helps
Hope this helps
Vag-Com follow up, the application chart for 1998-2004 has a big "N" for most items when compared to
DesmoTesta
06-26-2008 08:14 AM
profejh
03-09-2004 07:02 PM
Blue TooTh Fan
06-02-2003 03:24 PM
