VAg COm mods/ How to program/ list what you have
Hay i dont no if any one has don this. But i think it would be cool to have a listing of what mods are out their and how to program mods on audi vehicles through ross tech tools.
•Disable After-wipe of windscreen wipers
•Disable amber corner lights
•Disable amber side markers
•Disable Key warning (keyless models)
•Disable LED 'wink' on turn signal
•Disable "Lights are on" warning
•Disable NAV & Phone warning messages while entering data at speed
•Disable Seatbelt Chime
•Enable Adaptive brake lights
•Enable Ambient Interior Lighting Control
•Enable Automatic Gear selection shown in DIS
•Enable Automatic Hill Hold Assist 'lite'
•Enable Auxiliary ventilation
•Enable Battery meter
•Enable DIS with Efficiency Program
•Enable Double Disarm Beep
•Enable DRL Selectable via MMI
•Enable DRL
•Enable Euro parking lights that turn on signal at night
•Enable fog lamp to come on for the same side as that turn signal
•Enable Front Turn Signals as Parking lights
•Enable Gauge Test/Needle Sweep
•Enable Hidden menu in MMI
•Enable Import CDs to MMI's HD
•Enable Independent Fogs control with high beams
•Enable Lap Timer
•Enable LEDs remain bright for parking lights
•Enable Rear Tail Lights on with DRLs
•Enable Release Parking Brake without putting foot on Brake
•Enable Release Parking Brake without putting seatbelt
•Enable Remote Operation windows&sunroof
•Enable Reverse mirror tilt
•Enable Speed through MMI
•Enable TPMS
•Enable VIM on MMI
•Set Audi parking system - Switch OFF Speed
•Set Custom ADS settings
•Set Headlight washer - cycles
•Set Headlight washer - duration
•Adjust Consumption in DIS
•Adjust LED Brightness
Audi A4/S4 B8
VCDS (VAG-COM) codes
[09 – Cent. Elect.] [Coding - 07] -> [Dropdown] -> "x ** 8K1 955 119 ** WWS xxxx" -> Long Coding Helper -> Byte 1
Bit 3 - Remove check mark (1 = active)
________________________________________
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
Submodule 0
Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
[46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 3
Bit 2 - LEDs remain at full brightness with parking lights (1 = active)
Bit 7 - Turn off LED-strip DRLs with indicators (1 = active)
Disable "Lights are on" Warning
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 5
Bit 3 - Set to 0 to disable "lights are on" warning when you open the door.
[5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
Bit 2-4 – Seat Belt Warning inactive
[46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
[Hidden menu] [car] [carmenuoperation] [interior light] Set to 5
[Hidden menu] [car] [cardevicelist] [interior light] Enable
Reset MMI
[02 – Auto Trans] [Adaptation – 10]
Select “Single Gear Display” from top channel drop down menu
Select “D on/S on” from New value drop down menu
Enable Automatic Hill Hold Assist ‘lite’
[03 - ABS brakes][Security Access - 16] (Enter code presented by program)
[Coding – 07] -> Long Coding Helper -> Byte 1
Bit 6 set to 1 to enable hill hold assist.
http://www.audizine.com/forum/showth...r-the-A4/page2
[5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
Bit 1 – Set to 1
[Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
[08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 3 – Set to 1
Bit 4 – Set to 1
[Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
[Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
Reset MMI
or
[56 - Radio] -> Adaption -> Channel 39, add 16 to your value
Enable DIS with Efficiency Program for MY2010+ (Not a complete Program without the Start/Stop System)
[17 - Instruments] [Adaptation - 10] -> Channel 77
change 0 to 255
[46 - Central Conv.] [Adaptation - 10] -> Channel 63
Add 4
[09 – Cent. Elect.] -> [Coding – 07] -> Long Coding Helper -> Byte 3
Bit 5 set to 1
Enable DRL
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 2
Bit 1 = DRL via Front Side markers
Bit 2 = DRL via High Beams
Bit 3 = DRL via Fogs
Bit 4 = DRL via LEDs
Bit 6 = DRL via Side markers
Bit 7 = DRL via Tail lights
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 0 - Set to 1
[09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
Bit 0 - Check the box or change :Bit 0 set to 1
Bit 0- Check the box or change :Bit 0 to 1
Once the change has been made you can enable the front turn signals as DRL's by making the following change:
Bit 6 - Check the box or change :Bit 0 set to 1
[17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
Bit 0 - Check the box for "Gauge Test/Needle Sweep active"
Enable Headlights on all the time
Bit 5 - Check the box or change
Bit 5 Set to 1)
change 0 to 1
Use this hidden menu at your own risk.
Caution: Keep away from the "Bootloader"
[Hidden menu]
Main/Diagnose/Settings
Import Media
Set to 4 of 4 "Copy/Ripping"
Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
Enable Lap Timer
Bit 3 - Check the box for "Lap Timer active"
Enable Remote Operation Windows and Sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
Bit 2 - Set to 1
Bit 7 - DRL's via Tail Lets Active (1 = Active)
[53 - Parking Brake][Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 4 Set to 0
[Adaptation - 10] -> Channel 7 Set to 0
[52 Door Elect, Pass.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 4
Bit 4 and Bit 2 set to 1
[56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1
Does not work if NAV equiped
Enable TPMS
* You need the 1AT ABS unit – check your stickers (1AS does not work)
[Hidden menu] [car] [cardevicelist] [RDK] Enable
[Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
[03 - ABS Brakes]
[Security Access - 16] (probably with login code: 61378)
Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
The TPMS need to be enabled in the Instrument Cluster:
[17 - Instruments]
Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
Reset MMI
Enable VIM on MMI
[5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
[Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
[Adaptation - 10] -> Channel 48
Set to 255
Reset MMI
[10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
Set to 20 (max value in km/h)
Set ADS to specific preset Comfort, Auto, Dynamic or Individual
[09 – Cent. Elect.][Security Access - 16]
Set to 01 - Comfort, 02 - Auto, 03 - Dynamic or 04 - Individual
[Adaptation - 10] -> Channel 64
[Adaptation - 10] -> Channel 65
[Adaptation - 10] -> Channel 66
*Note all four channels needs to be set to the same value.
Set Headlight washer - Duration
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 6
change to e.g. 500
Set Headlight washer - Cycles
[09 – Cent. Elect.]
[Security Access - 16] [Adaptation - 10] -> Channel 26
change to e.g. 10
[17 - Instruments]
[Adaptation - 10] -> Channel 3
change 100 to xxx (see samples below)
Sample 1 - Calculation based on volume per distance (e.g. l/100km):
DIS: 9,3 l/100 km.
Real: 9,8 l/100 km. (100 * 9,8 / 9,3 = 105,38)
Channel 3 will be changed from 100 to 105
Sample 2 - Calculation based on distance per volume (e.g. MPG):
DIS: 23 MPG.
Real: 24 MPG. (100 * 23 / 24 = 95,83)
Channel 3 will be changed from 100 to 96
Adjust LED brightness
[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
Set between 5 and 100
Again, I take no credit for this information, most of the above is available on these forums and specialty websites as well as Ross-Tech's support pages. I only wanted to group all the info of the pertinant VCDS mods to our S4.
Not all the above has been verified, I'll be happy to re-edit this post to correct any info.
Oh and I'm not responsible for any screw ups this causes, good luck.
Can I get a few volunteers to nominate this post as a sticky?
•Enable DRL
•Enable Lap Timer
•Enable TPMS
•Enable VIM on MMI
Audi A4/S4 B8
Submodule 0
Reset MMI
Bit 1 – Set to 1
Bit 3 – Set to 1
Bit 4 – Set to 1
Reset MMI
or
change 0 to 255
Add 4
Bit 5 set to 1
Enable DRL
Bit 0 - Set to 1
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
change 0 to 1
[Hidden menu]
Import Media
Enable Lap Timer
Bit 2 - Set to 1
Enable TPMS
[03 - ABS Brakes]
[17 - Instruments]
Reset MMI
Enable VIM on MMI
Set to 255
Reset MMI
[09 – Cent. Elect.]
change to e.g. 500
[09 – Cent. Elect.]
change to e.g. 10
[17 - Instruments]
DIS: 9,3 l/100 km.
DIS: 23 MPG.
Michael Driscoll (02-12-2020)
•Enable DRL
•Enable Lap Timer
•Enable TPMS
•Enable VIM on MMI
Audi A4/S4 B8
Submodule 0
Reset MMI
Bit 1 – Set to 1
Bit 3 – Set to 1
Bit 4 – Set to 1
Reset MMI
or
change 0 to 255
Add 4
Bit 5 set to 1
Enable DRL
Bit 0 - Set to 1
Bit 5 Set to 1)
change 0 to 1
[Hidden menu]
Import Media
Enable Lap Timer
Bit 2 - Set to 1
Enable TPMS
[03 - ABS Brakes]
[17 - Instruments]
Reset MMI
Enable VIM on MMI
Set to 255
Reset MMI
[09 – Cent. Elect.]
change to e.g. 500
[09 – Cent. Elect.]
change to e.g. 10
[17 - Instruments]
DIS: 9,3 l/100 km.
DIS: 23 MPG.
•Enable DRL
•Enable Lap Timer
•Enable TPMS
•Enable VIM on MMI
Audi A4/S4 B8
Submodule 0
Reset MMI
Bit 1 – Set to 1
Bit 3 – Set to 1
Bit 4 – Set to 1
Reset MMI
or
change 0 to 255
Add 4
Bit 5 set to 1
Enable DRL
Bit 0 - Set to 1
change 0 to 1
[Hidden menu]
Import Media
Enable Lap Timer
Bit 2 - Set to 1
Enable TPMS
[03 - ABS Brakes]
[17 - Instruments]
Reset MMI
Enable VIM on MMI
Set to 255
Reset MMI
[09 – Cent. Elect.]
change to e.g. 500
[09 – Cent. Elect.]
change to e.g. 10
[17 - Instruments]
DIS: 9,3 l/100 km.
DIS: 23 MPG.
Stormghys (12-10-2019)
Not like it's proprietary information...
This doesn't seem to be the same on the 2016 A7/S7. I find these, along with the same message when entering the Audi Connect PIN to be annoying. It would also be nice to see the entire message on the MMI without it being shortened because the car is moving.
If anyone has been able to turn these off I would appreciate knowing how you did it.....
