VAG-COM read. Help with some codes please -
Address 01: Engine
Controller: 4D0 907 560 CE
Component: 4.2L V8/5V G 0002
Coding: 07752
Shop #: WSC 02325
WAUML64B12N130721 AUZ7Z0B2099716
2 Faults Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-00 - -
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0000 0000
I changed out the driver side primary and secondary... and passenger side secondary O2 sensors with Bosch sensors. Still getting that 17521 code. Help.
Also, I have parktronic on my 2002 4.2, but when i try to read channel 76, it says that it cannot read the computer. Do i have a loose connection somewhere? maybe a fuse?
can anyone help?
Thanks!
Coding: 07752
Shop #: WSC 02325
2 Faults Found:
P0441 - 35-00 - -
can anyone help?
Thanks!
I know it seems screwy, but bank 1 is the right bank in every car I've ever worked on, other than an 01 Toyota Land Cruiser. Replace that sensor also, and you should be fine.
Still looks like you need to do some diag work on the EVAP problem as well.
<center><img src="http://www.ross-tech.net/vag-com/misc-images/SensorsBanks.png"></center><p>
http://www.Ross-Tech.com
so pissed off after replacing (what I thought was) B1S1 on this Landcruiser, and having the light come on during the second drive cycle with the same code.
MCPaudiTT - DEFCON 1
08-08-2007 07:18 PM
lopxtc
01-09-2007 07:47 AM
NogaroPR
10
05-29-2006 08:38 PM
BlackS4tt (Josh)
VAG-COM Discussion
09-01-2005 07:33 PM
