VAG-COM unable to communicate with Airbag Module, no warning light.
I was scanning an Audi TT 2000 Roadster in order to buy it.
Doing Auto-scan, everything seemed ok (the owner changed the battery and did not reset the DTCs), and I know that the other things are cheap.
Although the car look in good condition all around, the central cap of the steering wheel is lightly damaged, and the worst is that my VAG-COM could not communicate with the air bag module, sending this message:
http://www.ross-tech.com/vag-com/tour/screens/4040airbagtimeoutb.png
There is no "air bag lights on". Nothing, but I could not communicate.
The owner said that the VW shop tested and it was ok. To close the deal he will bring the car to an Audi shop (another city) to show me and then do the business.
On another car (also a TT Roadster) the Auto Scan skipped the Airbag Module and I just realized that now that I was searching for a clue.
Is that a possibility that VAG-COM could not communicate and the Audi tool do?
What do you think about this?
I am concerned about this because this car is expensive here in Brasil (US$65k equiv.).
Thank you in advance.
These are the complete Auto-Scan:
Thursday,25,January,2007,16:58:11
VAG-COM Version: Release 607.3-UD
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine
Part No: 8L0 906 018 M
Component: 1.8L R4/5VT 0002
Coding: 05710
Shop #: WSC 04001
5 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
17925 - Main Relay (J271): Electrical Malfunction
P1517 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
18084 - EPC Warning Lamp (K132) Circuit: Electrical Malfunction
P1676 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18446
Shop #: WSC 01236
No fault code found.
Address 08: Auto HVAC
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00040
Shop #: WSC 01236
Address 35: Centr. Locks
Part No: 8N7 962 267
Component: Zentralverrieg.,DWA D04
Coding: 05758
Shop #: WSC 00218
5 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01616 - Signal Wire to Interior Monitor
36-10 - Open Circuit - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01617 - Please Check DTC Memory of Interior Monitoring
Address 45: Inter. Monitor
Part No: 8N7 951 177
Component: Innenraumueberw. D13
Coding: 00001
Shop #: WSC 00215
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 56: Radio
Part No: 8N0 035 186 A
Component: Radio D05
Coding: 00017
Shop #: WSC 01236
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 05710
Shop #: WSC 04001
5 Faults Found:
Coding: 18446
Shop #: WSC 01236
Coding: 00040
Shop #: WSC 01236
Coding: 05758
Shop #: WSC 00218
5 Faults Found:
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00215
1 Fault Found:
43-00 - Closed
Address 56: Radio
Coding: 00017
Shop #: WSC 01236
The instrument cluster is also conspicuously absent from your scan.
My guess is this car has some "issues".
-Uwe-
-Uwe-
http://www.Ross-Tech.com
awinn17
VAG-COM Discussion
07-05-2011 01:10 PM
TTsumibishi
11-01-2008 08:45 AM
