Vag-Tacho for Immo3
I'd like purchase a VAG-Tacho, to go with my VAG-COM, to pull the SKC. I have a 2000 A8L that appears, by Ross'(VAG-COM) description, to be Immo3. Anyone found a VAG-Tacho version that will work on Immo3 that does not just refer to Opels?
Tx
Roland
Tx
Roland
I would caution from buying vagtacho on ebay they cause more damage and there is no recourse if happens to you.
Visit your local dealer they might provide to you for a fee
I finally got the correct FCCID for my 02 S8, got the correct used key fobs and was able to program the keyless entry but was not able to pull the PIN code with the vag tacho to program the immobilizer. version 3.1 doesnt work. neither does the VAG KEY device from ebay. Even though it says 2002 S8 and up it didnt get the PIN - it just showed one digit.
VAG PIN Code Reader/Key Programmer Device via OBD2 | eBay
I have 2 ready to go cut keys but cant use them because of the PIN needed for the immobilizer.
Anyone successfully pull the PIN form a D2 S8?
Thanks!
Thanks!
applejacks
08-13-2007 12:32 PM
derek2079
07-30-2004 06:50 AM
