Will the Air/Fuel Ratio Calculation sheet on Ross-Tech work for all applications.......(more inside)
What I mean is, does this work even with non stock applications. I am testing a custom set up with aftermarket injectors, fuel pump, fuel rail, pressure regulator, maf.
I was wondering because I am getting weird numbers and thought it maybe applied to stock part or something?
A different/bigger MAF would be an exception and air/fuel
ratios would probably be different.
I understand the ratios are basically the same and optimal tunning is 14.7:1 in most cases. I was asking about the formula used to derive the ratio in the Ross-Tech link. They use assumed values and flow rates in both the MAF and injectors. I would imagine its a different formula if your car has all of those flowing differently.
scroll down to "Some Useful Off Site Links"
I used the HP vs. TQ spread sheet and got some very accurate numbers for my K03 with my mods as far as I can tell. The guy that made it was only off by 4 hp when he dyno tested and used his formula with Vag-Log info. I pulled 185.5 hp / 219.9 tq. Using that method. If anything I bet I can get slightly more because I can beat a K04 car that pulled 200whp on a dyno. Plus my car only hit 14 psi during the logs. I ususlly hit 16-17 steady spike 18.<ul><li><a href="http://www.ross-tech.com/vag-com/cars/index.html">http://www.ross-tech.com/vag-com/cars/index.html</a</li></ul>
You can definitely expect to see a different pattern (as you
suspected). I would keep a close eye on Air/Fuel ratios
as I think therein are some basic guidelines you want to follow
such as never going below 10.3 or above 17.5 or something...
I just threw those numbers in there, but I'm sure there is a
spectrum of specific air/fuel ratios you'll want to stay very close
to for optimal tuning as well as keeping things from going boom.
I don't know what those numbers are, but I'm sure if you ask
around you'll find out. You may even want to contact a
tuner/vendor such as APR or GIAC for that info if you can't
find it here.
As far as finding, or deciding upon a specific pattern such as
injector duty cycles and how they mesh with A/F ratios at 2k,
3.5k, 6k, rpm's is completely unknown for your custom setup,
but I'm sure as you continue to log you'll notice a pattern(s).
Also, you may be better off running a stand-alone boost
controller if you are swapping out injectors, so that you can
somewhat tune your car if so wish to go further down
that road.
find it here.
that road.
The guy that I am helping with this can not afford a air/fuel wideband right now and its just silly that he spent so much money on his car and didnt budget for this but still drives the car around. I mean its fully built from the bottom up with everything. His goal is 500 which I see as long reached. So needless we have no reference on where he is running right now. Thats why I have been doing this.
Imola_Tip_Soul-Ja
12-29-2005 06:02 PM
Imola_Tip_Soul-Ja
12-20-2005 07:09 AM
Imola_Tip_Soul-Ja
12-11-2005 12:17 PM
DarinS4Turbo
9
09-06-2002 07:37 AM
