Xenon Code 01539
2003 2.7t A6
I looked at this link: http://wiki.ross-tech.com/wiki/index.php/01539
I cannot clear this code no matter what! When I try Basic Settings I get ERROR Group 001 Not available and same with Group 002.. I also tried Saving 0 to Adaptation channel 00 but nada.
Measuring Block readings 4.51v in the front 2.29v in the rear.. looks like the rear is IN spec but the front is a little high and out of spec.
How do i get the front sensor voltage lower to be in spec (im assuming that once the front is in spec i will be able to clear the code and set Basic Settings)? I tried driving the rear and the front of the car up on ramps but the values only move about 0.05v at most either way
any tips?
any tips?
I believe those sensors are on a 0 - 5 volt scale so 4.5x would be implausible and the Basic Setting cannot run. Check the sensors and wiring while reading the live Measuring Block data.
If you need further assistance please post the Auto-Scan.
JoePGT5S
12-10-2017 02:27 PM
Flats
07-13-2015 11:23 AM
golfrsi
07-28-2009 01:55 PM
fussball.biturbo
10-09-2007 05:41 AM
