xenon range faulty
xenon range faulty
have the fault below along with the headlight symbol on the dis.
Address 55 -------------------------------------------------------
Controller: 4B0 907 357 B
Component: dynamische LWR D02
Coding: 00020
Shop #: WSC 02335
1 Fault Found:
00776 - Level Control System Sensor: Left Front (G78)
31-00 - Open or Short to Ground
This I believed to be the sensor, so purchased one from Audi, as a test I plugged it in without connecting it up to the suspension to see if this cleared the problem on the dis, it didnt. I measured the voltage going to the sensor - there are 3 wires - one ground, one +12v and the other i believe is the sensor going to the controller.
Where is the xenon level controller located, I need to check the connectivity at the module. Thanks in advance.
Ian.
Coding: 00020
Shop #: WSC 02335
1 Fault Found:
Ian.
With the sensor not fitted...
it will be at the limit of it's travel, so it's possible that this will still be seen as an error. Try fitting the sensor properly and looking again.
The error on the DIS probably won't clear until you clear the fault code on the controller with VAG-COM.
mart_o_rama
03-24-2013 11:26 AM
1 Bad DJ
09-04-2008 12:55 PM
