Excelerate Performance: STOPTECH Rotors, Pads, Lines and Big Brake Kits!!!
This is an AudiWorld Special Pricing Event for the Stoptech Big Brake Kit only.
Here is some important information on Stoptech’s BBK’s from www.stoptech.com:
Big Brake Kits improve stock performance in two areas. First, larger rotors increase heat capacity. Second, stiffer calipers and stainless steel lines reduce system compliance.
The key, however, is to increase heat capacity and reduce compliance without upsetting the stock front to rear brake torque ratio. If the brake upgrade you select adds too much front torque (as many do), you reduce your car's ability to utilize the tractive capacity of all of the tires to the maximum practical extent (even on ABS equipped cars) and you therefore create performance sacrifices. In addition, too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, which limits a driver's control of brake input on the race track.
Advantages of StopTech over other brake upgrades:
- Shorter Stopping Distances
- Better Brake Modulation
- Firmer Brake Pedal
- Less Brake Fade
Feature Benefit Summary:
- Balanced Brake Upgradesâ„¢ with optimum brake bias offer the shortest stopping distance with the best pedal feel
- Our patented AeroRotors® with the best airflow available result in better cooling, less fade and longer rotor and pad life
- The stiffest aftermarket calipers with patented bridge result in better clamping under hard braking and less pad taper
- Track testing of new applications ensures optimum performance
Big Brake Kits Include:
- 2 Piece Floating Directional AeroRotors: 328x28mm or 332X32mm or 355X32mm
- 4 Piston ST-40 Calipers or 6 Piston ST-60 Calipers
- Stainless Steel Brake Lines (Front or Rear)
- Caliper Mounting Brackets
- Street Performance Pads
OPTIONAL:
Standard Caliper Color: Red or black or silver
Custom Caliper Color: Yellow, Blue, Gold (lead time of 60 days depending on application and $200 extra per caliper set)
Slotted or drilled rotor (add $100 for pair of drilled rotors); zinc coating ($70 for pair)
![](http://i34.photobucket.com/albums/d121/Excelerate/stoptechoptions.jpg)
Stoptech's Front 4 Piston 2 pc 328MM Disc BBK Setup
![](http://i34.photobucket.com/albums/d121/Excelerate/bbk-2w-46-71.jpg)
Stoptech’s Rear 2 Piston 2 pc 328MM Disc BBK Setup
![](http://i34.photobucket.com/albums/d121/Excelerate/bbk-2w-23-71.jpg)
Shipping times will depend upon your location. Prices based on shipping to 48 continental states in the U.S.
Prices and applications are on our website:
http://store.excelerateperformance.c...t/g-52574.aspx
PM us though with your vehicle info (make, model, year, transmission type, AWD or FWD) and your zip code and state and what exact BBK you're looking for and we will get you a quote.
NOTE: Larger wheels may be necessary to accomodate space for larger caliper and rotor. Email me for info on how to check caliper clearance. Or you can go to www.stoptech.com and see how to check it.
For pricing on rotors, pads, and lines please visit our website:
http://store.excelerateperformance.com
Just enter in your vehicle information and choose STOPTECH as a brand.
AIM Screen Name: Excelerate04
E-mail: Excelerate@sbcglobal.net
or PM me.
RETURN POLICY
- ALL RETURNED AND/OR CANCELLED ORDERS ARE SUBJECT TO A 25% RE-STOCKING FEE PLUS ALL SHIPPING CHARGES (Includes original and return S&H fees).
- ALL AUTHORIZED RETURN MERCHANDISE MUST BE NEW, UNUSED, AND IN ITS ORIGINAL PACKAGING. ALL DOCUMENTATION, WARRANTY CARDS, INSTRUCTIONS, AND HARDWARE MUST ALSO BE RETURNED.
- ITEMS MAY BE RETURNED WITHIN 15 CALENDAR DAYS FROM THE RECEIPT OF MERCHANDISE.
- SPECIAL ORDERS ARE NOT RETURNABLE.
- ALL DEPOSITS ARE NON-REFUNDABLE.
EXCELERATE LLC
998 West Main St
Branford, CT 06405
(P) 203-483-6100 (F) 203-483-6101
www.ExceleratePerformance.com
Joshua Lockwood
Owner
- Less Brake Fade
OPTIONAL:
or PM me.
RETURN POLICY
EXCELERATE LLC
998 West Main St
Branford, CT 06405
Joshua Lockwood
Owner
Rippcurl69
07-31-2004 04:04 PM
ryoung
11-28-2002 05:36 PM
Pelican Pete
09-05-2001 04:18 AM
WetA4
05-09-2001 12:26 PM
