235/55-17 rubbing help
Rubbing on 235/55-17. Hi i just called 2 of my local Audi dealers to see if i can put my used all weather tires on my 2007 A4 3.2 quattro cabriolet. They both said fine no problems... So i put them on now i have a rubbing noise from inside the car. Any suggestions besides the obvious which is to go to a smaller tire. (unfortunately got to wait for tax return...)My previous were 235/45-17 but were totally bald. Had zero traction in snow and ice. I have put on 50% tread 235/55-17 goodyear RS-A's
AudiWorld Expert
So i have read about not having different tires on an AWD and changing sizes. But how much difference would 235/45-17 on the front and 225/50-17 on the rear affect the handling etc. i have read on the net that it will ruin torsion bars steering racks transmission etc...
AudiWorld Expert
As long as the outside diameter of the the tires is the same then it will be OK. You have to find websites that will tell calculate it. But having different tires that don't have the same outside diameter will hurt your diff. I have seen diff destroyed by people (and shops like Walmart) replace new tires on the rear and left bald ones on the front.
Ugh. I just tried the same thing with the same results. That sucks because I get a killer deal on the 235/55/17's too. I also wouldn't mind the extra gearing and softer ride. Of course I'm also worried about hitting a bump and it sending the tire into the fender... Oh well... Guess I'll be saving up for new tires ![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
Nobody knows if a 5mm spacer or something would work?
Metro
Wheels & Tires Discussion
11-08-2008 07:14 AM
S4MadMan
09-30-2001 11:13 AM
Greg Hardy
03-05-2000 07:45 PM
