Any difference between 15" and 16" steel rims for snow tires?
AudiWorld Expert
assuming you'll have lower profile tires on the 16s, then your steering response will be better thus improving dry-weather handling. 16" does nothing for the snow. It's the tire width that makes a difference in the snow - narrower is better.
AudiWorld Expert
But you also have to consider that you don't drive in the snow 100% of the time during winter (or do you live in Alaska?). On dry pavement, at cruising highway speeds, a heavy car like A4 (I'm assuming that's what you have) may be less stable when riding on 195-wide tire. So, something like 205 may actually be the best compromise between snow and dry winter roads. Again, it depends on your particular driving conditions.
I used 205/55/16 winter tires last winter, and I was very happy with them, but we don't get that much snow here in NOVA or PA and WV where I went skiing.
The 195/65 has a very tall sidewall which I don't like because it results in very "mushy" steering response - too much sidewall flex when turning. Nevertheless, quite a few A4 owners here run winter tires in that size without a problem.
Lurk'n
08-20-2002 07:19 PM
bushido
01-21-2002 06:49 AM
Gary @ Ronal
Wheels & Tires Discussion
11-22-1999 12:13 PM
