any way to make 5x100 fit onto 5x112 wheels safely?
basically what the title says. i have an a4 and would like to fit 5x100 wheels that i found in my area for cheap.. tried searching here as well as google. any help would be appreciated
If the offset is smaller allowing you to use spacers then you could buy spacer set that have hub mounting pattern 5x100 and rim pattern 5x112.
Does not work with original offset as spacer will push the rim out too much.
Rims and wheels are not the spot were I try to save money so get the proper rims and don't play around with it.
Phat_Rims
Wheels & Tires Discussion
12-10-2002 07:51 PM
robby
02-17-2002 07:54 PM
