Audi A3 wheel size
Former Vendor
A4s fall under the 35mm-42mm range. A3s range from 35mm-55mm. We've had problems with fitment on the A3s. If you want to test fit one wheel, we can arrange something.
Thanks Scott - I'm in Canada so it may be a bit of a hike...! I've bought wheels/tires from you for my BMW and they were mint, which is why I thought of you when I needed a set for the A3.
If it helps, the A3 is an 06 2.0T with standard suspension.
Cheers,
Dylan
Cheers,
Dylan
