Can I put 235/45/17s on the S4 Avus Wheels, the car in question...
Re:235/45/17s
It depends.
A 235/45R17 is ideal for the car, sure.
On the OEM S4 wheels, they are only 7.5" wide, so you need to make sure the particular tire you are looking at will accept a 7.5" wheel width as a minimum to safely mount onto the wheel. (Most 235s will need an 8" minimum)
If you have a question about your particular tire, give me a call & I will make sure for you!<ul><li><a href="http://www.tirerack.com/tires/index.jsp">Tires</a></li></ul>
pahiker
09-25-2003 10:20 PM
DesmoTesta
Wheels & Tires Discussion
06-13-2002 07:14 AM
Thermal
07-29-2001 07:17 PM
