Did the dealer over-tighten wheel nuts?
Changed to winter wheels and tires today. So difficult to remove wheel bolts I had to use a three foot bar on the lug wrench to budge them, and when they broke free some of them made a loud, awful cracking noise. Bolts seem OK.
I always install lug nuts carefully to 90 ft-lbs torque, but dealer had wheels off since I did so for wet braking delay inspection by Audi engineer.
Question: can I assume that the dealer over-tightened the nuts, or is it possible that the nuts were correctly tightened but froze up since? I did notice some rust on some of them (which of course I removed with wire-brush before reinstalling).
I find it a little hard to believe that my usually very reputable dealer wouldn't have their power wrenches set correctly. On the other hand...
My concern, apart from possible damage from over-torquing, is of course that some dark, rainy night on the highway, without my big cheater bar, I'll be unable to remove a wheel when I need to.
I 've been advised NEVER to use anti-seize on the bolts, although I do use it on the hubs.
Re: Did the dealer over-tighten wheel nuts?
I good thing to do is watch whom ever puts back on your wheels, watch them use a torque wrench, and torque each bolt to its required spec.
If you cannot, then redo them yourself later.
if ya want something done right..........
Rory
11-12-2004 11:26 AM
Lightweight-USPowah
Wheels & Tires Discussion
10-05-2003 10:51 AM
Jeff Vader - boscoj
08-26-2002 04:11 AM
Dismayed
11-08-1999 02:16 PM
