Do Mille Miglia Spider Plus wheels clear Stoptechs?
Does anybody know if 17" Mille Miglia Spider Plus wheels (et35) would clear Stoptech calipers? I have a 2004 A4 with Stoptech's 332mm BBK up front. Trying to search for a good 17" wheel for winter use but it must be able to clear the larger calipers. Came across these, but need to know before buying.
Thanks! =)
Thanks! =)
<center><img src="http://www.tirerack.com/images/wheels/millemiglia/swap/mm_spider_11_ci3_l.jpg"></center><p>Spider Plus? Is this the wheel here that we call Spider II? If so, it unlikely to clear the stoptechs from the info we have.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Fwheels%2FDisplayWheel.jsp%3 FwheelMake%3DMille%2BMiglia%26amp%3BwheelModel%3DS pider%2BII%26amp%3BwheelFinish%3DBright%2BSilver%2 BPaint">spider II</a></li></ul>
What 17" wheels do you know that would work with my setup? I'm not in any rush right now, but I will need a setup when winter arrives.
My OEM RS4 Style wheels that came with the Ultrasport package just clears the caliper (credit card thickness in clearance). Those have an offset of et43 for 18" wheels.
I also have an old set of Borbet Type R 18" wheels that I'm using with spacers since it doesn't clear (offset of et35).
The RS4 wheels are my summer daily wheels. I will eventually get rid of the Borbet wheels for possibly some OZ Superleggeras next year for track use.
Thanks for your help! =)
Right now the best priced 17" wheels that seem to clear are :
AT Italia S5
MM Action
OZ Record<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR8&url=/wheels/index.jsp">wheels</a></li></ul>
AT Italia S5
MM Action
jeffmill1
Wheels & Tires Discussion
10-30-2004 08:56 PM
roots
02-06-2003 08:18 AM
Skrill (RexxKw0nDo)
12-30-2002 02:45 PM
freak
12-05-2002 03:58 AM
Schlepcar
04-10-2002 11:53 AM
