? for Gary.
? for Gary.
Noticed that you have the Blizzaks LM 25s in stock 225/40/18. Would these fit an 04 S4 (235/40/18)? If so, what would be the adavantage or disadvantage in getting them in this size.
Thanks.
Thanks.
Re: ? for Gary.
Being that in that size the LM25 is an extra-load reinforced tire in this 225/40R18 size, you could use it on the S4, but you would need to run the tires at 44+psi to maintain correct load capacity. This will make the ride stiffer both due to the shorter sidewall and the increased Psi.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR8&url=/winter/index.jsp">winter tires</a></li></ul>
Wheels & Tires Discussion
05-12-2008 10:43 PM
KamS4
09-20-2004 05:09 AM
Gary.... is there anyway to recalibrate the speedometer after putting a larger tire and wheel on the
Ulilbastrd
06-16-2004 12:19 PM
