Gary or anyone else. Recommended tire pressures for VictoRacer V700 from Kumho
Got the VictoRacer V700 from tirerack pre-mounted on SSR's and balanced. I was wondering what the recommended tire pressure on these tires are?
Size:
Rear: 275/40/17
Front: 245/45/17
This is on a BMW 330ci.
What should they be set around COLD?
Thanks a lot
Size:
Rear: 275/40/17
Front: 245/45/17
Thanks a lot
Start with factory BMW pressures or 35-40 psi (whichever is higher) to begin with.
More info here http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=61
Then use this guide to adjust to your specific setup :<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Ftires%2Ftiretech%2Ftechpage.jsp %3Ftechid%3D58">http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=58</a></li></ul>
f3d
Wheels & Tires Discussion
12-08-2003 03:58 AM
