Going from OEM "Wineglass" w/ 35mm offset to a BBS RX with 45/mm offset should push the tire to
the outside of the car and be ok correct? I was using this link as reference
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
thanks!
thanks!
AudiWorld Expert
Which wineglass rims are you referring to? The 16x7 ones which came on B5 (and some C4 I think) had an offset of ET43, not 35.
Both wheel offset and wheel width will determine where the outer edge of the rim will be.<ul><li><a href="http://marksink.com/tire_wheel_offset/offset.html">Wheel offset calculator</a></li></ul>
onewickeda6
Wheels & Tires Discussion
04-07-2008 08:59 AM
Kinetic0510
12-27-2001 01:57 PM
wnut
08-21-2001 11:13 AM
Nick T.
07-12-1999 08:58 PM
