How to store "ski trip" tires/wheels?
Guest
Posts: n/a
OK, so I bought my SP4000 A/Ss for my ski trip, but now its time to take them off again for my stock 8000Es. So how should I store these tires? Do I need to wrap them in anything? Unfortunately, I don't have a garage, so I was going to just be storing them over the carport. Will being "outside" damage them? Do they need to be driven on every so often? They aren't going to get too old, as I imagine in a year tops I will be done with the 8000Es and be then using the 4000s as my full-time tires (remounted on my stock wheels), but will they get damaged from sitting around for 9 months unused, outside? Thanks.
Guest
Posts: n/a
If you have an Avant: Pack a little more lightly and throw a wheel/tire set in the back.<p>If you have a sedan: pop out the bench seat (it has two clips), fold down the rear seat, put a wheel/tire set in the back.<p>And yes, there's enough room. I fit a wheel/tire set (17x8/Pirelli) plus another set (15/Blizzak) in the back of an A4 sedan awhile ago.<p>Cameron<br>
Guest
Posts: n/a
1. Prevent rust/corrosion of wheel - apply wax<br> or other sealant<br>2. Rubber probally degrades in sunlight from UV - <br> cover or keep out of sun<br>3. Nitrous oxides attack rubber - don't place in <br> area where electric motors operate. If outside shouldn't be problem unless you live in high ozone air pollution - not much can be done.<br>4. keep undue weight off<br> Maybe try silicone spray on rubber to minimize oxidation.<br>Happy trails!<br>
Guest
Posts: n/a
On summer /winter tires for Audi and track tires for Porsche, store them flat stacked on top of one another. Have been doing this for 20 years with no problems. They are stored in a garage, tho; skimants has some good additional points.
Guest
Posts: n/a
Don't remember if I read this on the Tire Rack site, or the Pirelli site. Nevertheless, they stated to stack the wheels/tires, fully inflated, on their sides, no more than 4 high. Also to make sure that they are stored off the ground/floor. (on a wood crate for example. Check the inflation at least every two months, and keep them dressed with some tire dressing. (don't try to eat them though) :-)
Audi A4 2006 A4 Wheel and Tire Set
GarmischP
09-25-2014 06:02 PM
A4AdMan
12
10-04-2006 12:15 PM
