hubcentric ring
AudiWorld Expert
<center><img src="http://www.1010tires.com/images/accessories/hubrings_large.jpg"></center><p>Hub centric rings are manufactured so that when they are installed on a vehicle, the wheels are located directly off of the centrer flange of the brake drum or rotor. This is done to insure that the outer beads of the wheel are concentric with the wheel bearings. The result is a much truer, better balanced tire/wheel assembly. This is very important with modern high tech suspension systems.<ul><li><a href="http://www.tirerack.com/a.jsp?a=AR4&url=%2Fwheels%2Ftech%2Ftechpage.js p%3Ftechid%3D91">Tire Rack</a></li></ul>
ddg=shinebox racing
Wheels & Tires Discussion
03-12-2005 05:14 AM
SkoS4
03-28-2000 07:37 AM
