Mis-matched tires on Audi A6 4.2Q
I have always been told not to mis-match tire treads/tread life on my Audi.
I have a two new M+S tires, and two that are 1/2 way through their tread life.
Should I bite the bullet and buy two new tires to match, or put the new ones on the rear, older on the front?
Thanks,
HSS
Thanks,
HSS
AudiWorld Expert
and then save up for replacing the diff.
4/32nd difference in outside diameter is all that is allowed by Audi. I have see cars that had to have diffs replaced because of miss matched tires.
Choice would be to buy two more new M+S tires or to shave down the two new ones you have to match.
It will create a small differential across the, uh, differential. Which is why its called that :-)
Ideal? No. Life threatening? Only if you're a lawyer protecting some big company.
Grant
Grant
AudiWorld Expert
diff<ul><li><a href="http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=18">Tire Rack Tech Guide</a></li></ul>
If you buy two new ones now, then you'll face the same dilemna again when your old ones are done.
Also, I'd put the new ones on the front personally, since they wear down faster up there. However with this configuration you'd need to be careful as the rear would have lower grip especially in heavy rain and the back end of the car may want to step out.
roughyear
08-16-2006 05:36 AM
Kricka
11-03-2003 01:31 PM
CRD99
09-16-2003 07:42 AM
