need a badass winter tire Nokian WR or RSI? lots of deep snow and ice, dry handling is sacrificable
If you want max ice and snow traction, go with the Nokian RSi.
The WR are more of a performance winter tire... Great on the dry, great in the snow, and ok/decent on the ice.
If you want to straddle between the two, you can get the NOkian Hakka2 (without studs). It's tread stiffness is between the WR and RSi... so it won't be as agressive on the ice as the RSi, nor will it be as good on the dry as the WR. I'll probably be running the hakka2 as my next winter tire (if the hakka4 isn't here by then)
Edit: or if studs are legal in your area and you don't mind running them.. hakka2 studded is the ultimate.
kraeburn
Wheels & Tires Discussion
15
12-17-2006 03:29 PM
unA4dable
12-15-2000 12:49 PM
