Need new tire
I ve recently bought an Audi a6 quattro and recently damaged the passenger side tire. do i need to replace all four tires? do i need to buy the same exact tire or can it vary in terms of the load index and speed? currently ihave the 97H which doesnt come with tire mileage warranty, however the 93Y does (michelin) can i get all four of these tires? thanks
You can replace one tire if it is the exact size, brand and model of tire and the exsisting tires have 6/32nds of tread depth or greater. If your current tires have less tread depth, you can have the new tire shaved down to match that depth.
In order to answer the other questions, I'll need the year and model of your A6.
Others may disagree, but I've always maintained that people who insist on waiting to replace tires until the tread is worn out are depriving themselves in a big way. You may have tread left, but the sidewalls are shot after 30,000 miles and your ride and cornering are never going to be the same as on a tire with 10,000 or fewer miles. Just like running shoes. All of which is to say, don't worry too much about treadwear warranties when buying tires -- leave the treadwear warranty factor to ma and pa who go out looking for Uniroyals to put on their Pontiac Bonneville.
As long as you're replacing all four tires, yes, you can use a 93Y rating.
When you asked : "do i need to replace all four tires? do i need to buy the same exact tire or can it vary in terms of the load index and speed?" it sure seemed like your question was about replacing one tire versus having to buy all four tires.
you are absolutely right my question was do i need to replace all or just one tire. the wording on my reply was not what i meant. i was asking another question. thanks for your help. id rather get the 93Y than the 97 H if the lower load index will not make a big difference.
xiaoshao
Q7 MK 1 Discussion
11-08-2008 01:10 PM
sohcrates
01-27-2006 07:27 PM
Mark Heuchert
Wheels & Tires Discussion
03-11-1999 02:34 PM
